Clearence Between Roof Sheathing - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2015, 06:50 PM   #1
Rewards Points: 850
clearence between roof sheathing
so im doing a metal roof on a new construction home and noticed that the flexible water lines coming out of the top outer wall plate are right against the underside of the roof sheathing. i thought there was a code on distance, 2", not sure seeing as im not a plumber.
hotrod351 is offline   Reply With Quote
rerplace roof on 200 year old house newroof Roofing/Siding 7 11-24-2013 05:23 PM
Sheathing for concrete tile roof? RM575 Roofing/Siding 3 08-04-2013 10:03 PM
Protecting patio roof from water comming from house roof alekas Roofing/Siding 2 07-30-2013 09:40 AM
Roof Sheathing Thickness Clutchcargo Building & Construction 8 09-23-2009 01:13 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
