Clearance For Cleanout - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2017, 10:07 PM   #1
Structural Steel Detailer
Rewards Points: 20
Clearance for Cleanout
I have a cleanout in my basement floor for the drain line right before the pipe leaves the house. If I build walls on two sides of the cleanout how much clearance would be required?
kypper is offline   Reply With Quote
Range hood clearance to top of gas range less than minimum joemc3 Appliances 9 02-28-2013 01:42 AM
Above Roof Vertical Clearance - E3504.2.1 JeepNick Electrical 10 11-01-2011 09:58 PM
Sub panel clearance question Red Squirrel Electrical 2 05-09-2011 09:53 PM
Clearance for double oven installation Steeler99 Building & Construction 1 01-30-2011 05:16 PM
Furnace Clearance avtck HVAC 0 01-02-2010 09:13 PM
