Cleaning A Toilet Bowl With A Pumice Stone - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-10-2015, 07:48 AM   #1
Rewards Points: 1,093
Cleaning a toilet bowl with a pumice stone
I have a stubborn ring in my toilet bowl which will not come off with a regular brush.
I've read on the Web that you can remove such a ring with a pumice stone. Well, I bought one recently from the Christmas Tree Shop. But I've not used it yet.
I thought it might be a good idea to first ask whether others have used a pumice stone to clean their toilet bowl. My biggest fear is creating scratches on the bowl.
stripedbass is offline   Reply With Quote
Old 11-10-2015, 07:55 AM   #2
Rewards Points: 18,990
It's not going to scratch the bowl.
Bar Keepers Friend also works good.
Sold in the cleaning products area.
Old 11-10-2015, 08:23 AM   #3
Rewards Points: 6,578
Pumice is too soft to harm the bowl and unless it it used in conjunction with an acid, if hard water is causing the ring, it will take nearly for ever to remove it.
Lower the water level below the ring and and apply an acid. When the chemical reaction ceases, repeat. Try your pumice between applications. It will remove what the acid loosened.
A common household cleaner " The Works " contains phosphoric acid that is fairly effective. A janitorial supply will have an acid that's strong enough to speed the process but not recommended on stainless or lavatory metal drain fittings. With those I recommend running the bath exhaust fan.
Toilet bowl leaks and rocks--Is flange too high? Daneel Plumbing 5 01-26-2015 10:01 PM
Defective Gerber Avalanche toilet bowl? arandles Plumbing 1 01-26-2013 05:25 PM
Is NeverScrub Automatic Toilet Bowl Cleaner bad for any part of my plumbing system? bigdaddydavy Plumbing 2 11-29-2012 11:37 AM
Water draining into toilet bowl but not from tank black00 Plumbing 6 09-19-2012 08:28 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
