Clean Stain From Vanity Surface - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-29-2016, 05:25 PM   #1
Rewards Points: 129
Clean stain from vanity surface
I am updating a bathroom with a new faucet. I was finally able to remove the old (3-hole) faucet system. The new faucet fits in the single center hole. The problem is that there is a stain around the left (hot) former faucet hole. I have tried a variety of cleaning agents -- bon ami, a paste of baking soda & lemon, coke, toothpaste. Nothing has worked.
Any suggestions about how to remove a brownish (rust colored) stain around a hole in the counter on top of a vanity?
Thanks a lot!!!
Daneel is offline   Reply With Quote
Old 12-29-2016, 06:17 PM   #2
Rewards Points: 18,998
Re: Clean stain from vanity surface
We can not see what your seeing without a picture.
If it's rust I'd be using "The Works".
Any dollar store should have it.
Old 12-29-2016, 09:36 PM   #3
Rewards Points: 4,822
CLR or Lime Away are good for rust as well, as long as the surface is safe for them to be used.
stick\shift is offline   Reply With Quote
Old 12-30-2016, 11:30 AM   #4
Rewards Points: 312
what material is the counter?
KPDMinc is offline   Reply With Quote
Old 12-30-2016, 01:26 PM   #5
Rewards Points: 1,952
If its marble or synthetic marble use rubbing compound for a car and a buffer.
Old 12-30-2016, 04:10 PM   #6
Rewards Points: 288
You should try to find a deck plate that fits your faucet, or use a 3 hole faucet. Unless you have some other plan for covering up those holes. Apart from the looks, you're risking getting splashed or spilled water running down into your vanity.
BlackTiger is offline   Reply With Quote
Old House Surface Prep for Exterior White Stain glilley Painting 9 01-26-2015 01:04 PM
HVAC vent under bathroom vanity? RickSK Kitchen & Bath Remodeling 3 06-05-2014 08:01 PM
Vanity light install help needed hoyt79 Electrical 4 02-28-2014 04:57 PM
Best way to clean dust off surface being refinished? darsunt Carpentry 10 03-18-2012 08:38 AM
How to build/attach wall hung bathroom vanity NewHomeDIYGuy Carpentry 13 12-28-2011 02:17 PM
