Clean Out Plug - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By Yodaman
  • 1 Post By Ghostmaker
Old 10-15-2016, 09:09 PM   #1
Rewards Points: 740
Clean out plug
This clean out is 3" and the threading is stripped so I can not use a screw in plug. I tried the 3 " plug with a wing nut but the water still dripped.
crescere is offline   Reply With Quote
Old 10-15-2016, 09:12 PM   #2
Rewards Points: 740
Re: Clean out plug
I tried a 4" Fernco cover and screwed it as tight as possible, but it still leaked.
Old 10-15-2016, 09:14 PM   #3
Rewards Points: 740
Re: Clean out plug
Looking at the picture above that is the main stack pipe coming down. If I cut all the bottom part out to replace with PVC will I have to somehow suport the main stack?
Old 10-15-2016, 09:16 PM   #4
Rewards Points: 740
Re: Clean out plug
The guy at the plumbing store said that lead plugs cant be sold anymore even for drains.
Old 10-16-2016, 09:14 PM   #5
Rewards Points: 740
Re: Clean out plug
Anyone?
Old 10-18-2016, 06:17 PM   #6
hkstroud's Avatar
Rewards Points: 6,694
Re: Clean out plug
Did you clean up the threads before you tried to screw in the plug. I assume a brass or PVC plug.
hkstroud is online now   Reply With Quote
Old 10-18-2016, 06:40 PM   #7
Property Mgt/Maint
Rewards Points: 8,202
Re: Clean out plug
You might want to try the Fernco cap again. But this time smear the hub with plumbers paste or a small bead of plumbers putty. If it still leaks, buy a new Fernco coupling that will fit the outer hub and adapt to a new PVC clean out assembly.
MTN REMODEL LLC likes this.
Yodaman is offline   Reply With Quote
Old 10-18-2016, 07:32 PM   #8
Rewards Points: 1,950
Re: Clean out plug
Get a wire brush for your drill and clean the outside of the cast iron before applying a fernco.
Ghostmaker is online now   Reply With Quote
Leaking main drain clean out plug. dakornblum Plumbing 2 10-26-2010 06:20 AM
20 amp plug MikeyP Electrical 6 01-03-2009 09:04 PM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 07:44 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 08:07 PM
