Clean Out Plug - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-02-2016, 02:12 PM   #1
Rewards Points: 740
Clean out plug
When a plumber did some drain work he had to knock the clean out plug going to the sewer with a hammer. This stripped the threading. The opening is 3". Since I can't screw in a cap I put a 3" cap with the wing nut that is supposed to expand. I snugged it in and it seemed tight, but water just drips out when the toilet is flushed or the bath is run. What can I use that will not leak? Bear in mind the threads are stripped. Thank you.
crescere is offline   Reply With Quote
Old 10-02-2016, 03:07 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,600
Re: Clean out plug
Why didn't the plumber fix before he left?
Old 10-02-2016, 03:13 PM   #3
Rewards Points: 740
Re: Clean out plug
I agree, but it is too late now. He was really a sewer cleaner person.
Old 10-02-2016, 04:03 PM   #4
Rewards Points: 3,208
Re: Clean out plug
I assume you mean a 3in rubber plug with wing nut. They usually work for the short term as a quick fix. Are you sure its not a 4in?? Sounds like maybe you got the wrong size or its having trouble getting a good seal because of the threads.
Please post a picture. Thank you.
jmon is online now   Reply With Quote
Old 10-02-2016, 04:04 PM   #5
JUSTA MEMBER
Rewards Points: 3,148
Re: Clean out plug
You insult all plumbers by calling the Rooter service idiot a plumber.
I had a rooter service bust up 10 feet of pipe with their aggressive action, then just ask for payment and say to get it fixed.
No apology nor offer to pay for the repair .
As for your leak, try some of that FLEX-SEAL spray, rubber in a can.
I was skeptical myself before I tried it, and was amazed at how well it worked.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
jmon (10-02-2016)
Old 10-02-2016, 04:24 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 164
Re: Clean out plug
Google lead fit all plug. It should seal.
Old 10-02-2016, 08:16 PM   #7
Rewards Points: 740
Re: Clean out plug
So that will work even if the threading is all stripped?
Leaking main drain clean out plug. dakornblum Plumbing 2 10-26-2010 06:20 AM
20 amp plug MikeyP Electrical 6 01-03-2009 09:04 PM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 07:44 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 08:07 PM
