Clean Out Plug - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-27-2016, 10:18 AM   #1
Rewards Points: 740
Clean out plug
Hello all. I have old cast iron sewer lines, and I recently had them worked on. The 3 1/2" clean out iron plug had to be forcefully twisted out due to rust. I am trying to put a new plug in there, but it is not going into the grooves. I have brushed and cleaned the grooves out with a wire brush, but still no results. I twist the cap in, but it just will not follow the screw grooves in.
I tried one of those drain plugs with a wing nut, but it only comes in 3" size. The water leaked out of it. Please tell me what to use. This job is taking way too long.
crescere is offline   Reply With Quote
Old 03-27-2016, 11:01 AM   #2
Rewards Points: 106
Re: Clean out plug
lead plug and just hammer it in and hammer it off...those threads are gone, so dont even bother trying to thread anything into them..
goobertime is offline   Reply With Quote
Old 04-02-2016, 08:18 AM   #3
Rewards Points: 740
Re: Clean out plug
How would I get the plug out if I need to have it cleaned? This must be a common problem, right?
Old 04-02-2016, 09:08 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,308
Re: Clean out plug
Ayuh,.... They come in Many sizes, 'bout every 1/2",.....
Look at a plumbin' supply shop,....
Old 04-02-2016, 08:45 PM   #5
Rewards Points: 208
Re: Clean out plug
Grainger has them.
partner is offline   Reply With Quote
Old 04-02-2016, 09:56 PM   #6
Rewards Points: 1,950
Re: Clean out plug
Usually a brass plug can be found at a local hardware store. I'm not talking home depot or lowes.
Old 04-02-2016, 10:45 PM   #7
Re: Clean out plug
Also this will work if you messed your threads up.
http://www.supply.com/test-tite-test...-83689/p474157
The Following User Says Thank You to Ghostmaker For This Useful Post:
SeniorSitizen (04-03-2016)
Leaking main drain clean out plug. dakornblum Plumbing 2 10-26-2010 06:20 AM
20 amp plug MikeyP Electrical 6 01-03-2009 09:04 PM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 07:44 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 08:07 PM
