Choosing Plastic Pipes For Pool Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2016, 02:02 PM   #1
NateDavinci's Avatar
Rewards Points: 2
Choosing plastic pipes for Pool heater
I'm building a solar water heater with solar vacuum tubes, For my 4' pool. I have nine 20" solar vacuum tubes. Which I intend to fix 3 each into 3 separate plastic tubes. This device will either percolate (like a coffee maker), or I can use a small pump, to pump water to the lower segment, spilling or 'tubing' back into the pool from the top.
I'm needing a (clear non-UV-resistant) plastic tube. That can withstand boiling water and the steam a the top. The dimensions need to be greater than 2.5" inside diameter, available in 4-6 foot segments.
I've seen acrylic tubes that can withstand 180 degrees F, but need 212-300'ish or more, and an unknown pressure if I percolate. Aiming less than $100.
NateDavinci is offline   Reply With Quote
Tags
pool , tube
Help Needed Choosing 220v or 120v Tankless Water Heater and Proper Amperage wonderworm Electrical 13 11-09-2012 07:36 AM
Help Choosing new Water Heater adgjqetuo Plumbing 17 02-25-2012 08:46 PM
help choosing toe kick heater lobstercraven HVAC 0 12-01-2011 08:07 AM
choosing a heater for the garage ChrisJJ HVAC 3 11-30-2010 04:27 PM
Choosing an electric water heater brand? coyote556 Plumbing 6 11-06-2007 09:57 PM
