Cholorine/Water Solution Feed Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2017, 10:34 AM   #1
Edw
Rewards Points: 40
Cholorine/Water solution feed pump
Hello Folks. I treat our well water with a solution of chlorine and water feed by a Chem-Tech Pulse Feeder Pump. The pump makes a whining sound each time it runs. Does anyone else have this situation or does anyone know of a chemical solution pump that is quiet? Thanks to all!
Edw is offline   Reply With Quote
Old 07-25-2017, 02:36 PM   #2
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
Re: Cholorine/Water solution feed pump
Might try a stenner series , they might be a little more quite for you..
Has your pump always had this noise?
Akpsdvan is offline   Reply With Quote
Old 07-25-2017, 10:25 PM   #3
Edw
Rewards Points: 40
Hello Akpsdvan. Yes this pump has always made the whining sound. Did not think too much about it until recently because I may be putting the house up for sale in the near future.
Sump pump check valve, on pump or spliced in pipe? ponch37300 Plumbing 1 06-18-2016 12:26 PM
Heat Pump Thermostat Replacement BuckeyeAaron HVAC 81 02-01-2016 04:00 AM
Help with Sump Pump Issue (Drainage as well) neverlandpirate Plumbing 2 12-30-2015 07:57 AM
replaced flooded convertible jet pump, pressure will not go over 30 lb. dcreech Plumbing 4 09-18-2011 10:14 PM
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 06:51 PM
