Chinese Tankless Off EBay - NON POTABLE??? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
Old 01-12-2017, 02:03 AM   #1
Rewards Points: 18
Angry
Chinese Tankless off eBay - NON POTABLE???
I recently purchased a 24kw/3.2Gpm Lpg tankless for C$200 shipped and imported. Ebay # 201731789713
I live off the grid, so having the natural draft flue and battery igniter was a plus to save precious solar power.
When thumbing through the cryptic and confusing chinglesh "manual" it clearly states that the heated water is not for drinking.
So did the pricks use lead solder, or maybe the solder flux is toxic? Do USA made units also state this by anyone's recollection?
dehv is offline   Reply With Quote
Old 01-12-2017, 04:39 AM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,710
Re: Chinese Tankless off eBay - NON POTABLE???
Does this unit have any ULC listing on it?
I don't think I would ever install something like that in my home if it doesn't.
I think potable water is probably the least of your worries.
123pugsy is online now   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
dehv (01-15-2017)
Old 01-12-2017, 05:24 AM   #3
Rewards Points: 80
I've never seen one that wasn't for portable water, but then again I also didn't see one that was that cheap either. It's clearly not modulating or anything.
I have no idea what they used in their construction, but the major companies selling in this market follow the rules. (electrical, gas, plumbing and potable water aspects. There's a lot of safety devices in modern devices.)
It at least looks like its spark ignition and a plus. It may even be a plate style cross heat exchanger. The venting probably won't match anything that you'll find locally. Make sure that you use special metal venting if using it inside. (B-vent is not suitable) Use aluminum venting if it's all outside.
Cheers!
supers05 is offline   Reply With Quote
The Following User Says Thank You to supers05 For This Useful Post:
dehv (01-15-2017)
Old 01-12-2017, 05:30 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 898
How can a gas WH be listed as 24KW?
Sent from my RCT6203W46 using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 01-12-2017, 07:02 AM   #5
Rewards Points: 281
When I looked at the item you bought, it's a set that includes a shower head. It's a style of shower water heater very common in Asia, Europe and Latin America. I think I also saw similar shower water heaters in New Zealand.
Anyway, I think the "heated water is not for drinking" reminder is because the heater is intended to heat shower water. The manufacturer doesn't intend for you to modify it to heat your whole house water supply or your kitchen cooking and drinking water. There's probably no health hazard but then, I've only ever used water heaters like that for showering. Haven't encountered any modified for kitchen use.
Druidia is offline   Reply With Quote
Old 01-12-2017, 07:05 AM   #6
Rewards Points: 281
BTW, shower water heaters are also sold on Amazon.
Old 01-12-2017, 07:38 AM   #7
Rewards Points: 80
Metric
Cheers!
Old 01-12-2017, 08:26 AM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 898
Metric what? What does the KW mean?
Old 01-12-2017, 08:58 AM   #9
Rewards Points: 80
It's a heat (energy) measurement. kJ is another, but for heating they seam to like kW.
Cheers!
MTN REMODEL LLC likes this.
Old 01-12-2017, 12:08 PM   #10
Rewards Points: 80
1 watt = 3.41 btu
Cheers!
Druidia likes this.
Old 01-12-2017, 01:55 PM   #11
Rewards Points: 118
I always thought you weren't supposed to cook with or drink water from any hot water tap because the hot water could leech bad things out of the pipes anyway.
zolakk is offline   Reply With Quote
Old 01-12-2017, 02:31 PM   #12
Rewards Points: 44
I haven't heard that before, but I have heard that you should run cold water for a few minutes in the morning if your house has copper plumbing that was put in when lead solder was still allowed.
abrowning is offline   Reply With Quote
Old 01-12-2017, 03:52 PM   #13
Rewards Points: 288
I stopped cooking with hot water after the first time I drained down a water heater.
I haven't heard that it's a health risk, though. Maybe in really old houses or something but I'm sure that for a long time the material specs would demand that the pipes not contaminate water regardless of its temperature.
ChuckF. likes this.
BlackTiger is offline   Reply With Quote
Old 01-12-2017, 05:15 PM   #14
Rewards Points: 80
Hence the difference between potable and non -potable specifications.
Cheers!
Old 01-13-2017, 12:09 AM   #15
Rewards Points: 281
That's quite possible. High temp generally accelerates chemical reactions. Leeched compounds/molecules will depend on the pipe material and age (extent of corrosion), among others.
I have an instant hot water heater under the sink with a 5/8-gal stainless steel tank. Filtered water feeds into it. The heater tank is then connected to a hot/cold water dispenser faucet. That's my source of drinking/cooking hot/room-temp water. It's easy to flush out the entire content of the tank. I suppose the hot water in the tank is cleaner than hot water that has to flow through the usual house water supply pipes - what are they? Copper or galvanized iron?
REplacing water heater - PV, DV, or Tankless? curls00 Plumbing 5 12-09-2010 12:21 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
One Tankless Water Heater for Hydronic & Potable? VIPSpecialNeeds Plumbing 3 07-30-2009 03:09 AM
Tankless hot water heater??? psychocandy Plumbing 1 03-22-2007 10:41 PM
