Checking Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-02-2016, 11:00 PM   #16
Rewards Points: 1,866
I have to mention this some cities have raised the outside pressure on the water lines due to having older system with undersized mains. I would also call your water provider to find out what the outside feed pressure is. If it is high you may need more then one PRV valve to lower the house to 60 lbs.
A single prv can only do so much.
Info to read up on
http://www.watts.com/pages/learnAbou...s.asp?catId=64
Ghostmaker is online now   Reply With Quote
Old 01-03-2016, 06:00 AM   #17
raylo32's Avatar
Rewards Points: 1,500
OP, does you house have sprinklers? If so I believe they usually operate at full city pressure.... at least they do here and it happens to be 85 psi, which is what my house would go to when my PRV failed
In my house there is a separate gage to show the sprinkler system pressure. The feed for it is just upstream of the house main shutoff valve (sprinkler system has a separate shutoff that is tagged open) so it is easy for me to compare city pressure to house pressure on the 2 gages. If you have sprinklers but for some reason the feed is not contiguous with your house water supply maybe the gage is elsewhere.
Live long and prosper.
raylo32 is online now   Reply With Quote
Old 01-03-2016, 11:15 AM   #18
Rewards Points: 34
No sprinklers and unfortunately no gauges installed in the lines.
oldave79 is offline   Reply With Quote
Old 01-05-2016, 10:22 PM   #19
Rewards Points: 34
So, I had a plumber come out today. He confirmed my pressure readings with his gauge and checked PRV and expansion tank. Builder grade PRV wasn't functional, and expansion tank was filled with water and wouldn't take any air. Both were replaced, with an upgrade on the PRV to a sturdy looking Watts model. Pressure is now at 60 PSI.
Thanks to everyone for the insight!
The Following User Says Thank You to oldave79 For This Useful Post:
jmon (01-06-2016)
Intermittent Low Water Pressure Mystery bmbouter Plumbing 5 10-27-2015 04:54 AM
Increased Water Pressure mike123333 Plumbing 18 04-11-2015 05:59 PM
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 07:37 AM
Check valve gimaarob Plumbing 13 10-27-2011 10:13 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
