Check My DWV Setup Please - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-09-2016, 11:55 AM   #16
Rewards Points: 127
In my jurisdiction the permit is actually owned by the building owner. So I as the homeowner can obtain the permit and if drawings etc are required I have to get them from my architect, engineer or contractor and submit them with application. I don't need to know anything about the topic if I am not doing the work. Or I can have my contractor act as my agent and obtain the permits in my stead. There is normally an extra fee payable to the contractor for this service . Money well spend in my book. If I pull the permit I can work on most things in my personally owned single family dwelling but the work still needs to inspected and meet current requirements .
jimn01 is offline   Reply With Quote
Old 03-09-2016, 01:54 PM   #17
Rewards Points: 1,856
Originally Posted by WhatRnsdownhill View Post
one of the towns I work in will let the homeowner do electric, but only after passing a written test at the building dept, if they fail, its a one time chance, and not for plumbing, but that was years ago, so maybe it has changed...
That might be a local thing. But Ohio has taken the view that the homeowner is allowed to do his own work as long as it is inspected to code. That does not mean hiring a non licensed person to do the work though.
The Following User Says Thank You to Ghostmaker For This Useful Post:
ben's plumbing (03-09-2016)
Old 03-11-2016, 09:43 PM   #18
Rewards Points: 1,182
Here's the fixed drain pipes for the kitchen branch
Check my DWV setup please-1457754087083.jpg   Check my DWV setup please-1457754130790.jpg
I'm just a lay person doing DIY as a loner. Eliminating K&T, L&P and sagging structure one room at a time.
WillK is offline   Reply With Quote
Old 03-12-2016, 04:00 PM   #19
Re: Check my DWV setup please
Get the drain supported please. That 3 inch pipe for a hanger is such a waste. LOL
Old 03-12-2016, 05:11 PM   #20
Yeah, that was temporary. It was late and I just wanted to make sure the fresh glue didn't sag and lose the slope since I knew I didn't have hangers on hand and I wasn't going to be back with them until today.
Backstop / Check valve placement whirlpool Plumbing 10 05-19-2013 11:32 AM
Heating System Check Valves ajberezo Plumbing 2 04-11-2013 12:13 PM
Sanity check: re Low-V Transformer. rokosz Electrical 11 02-17-2013 09:59 AM
Check valve for tub drain? roasted Plumbing 19 01-01-2013 09:15 AM
Do I Need to Call in a Electrician to Check This Work? taras1 Electrical 6 12-13-2010 05:07 PM
