Check Balve On Sump Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2017, 03:15 PM   #1
Rewards Points: 36
Check Balve on Sump Pump
I have a sump pump with a silent check valve. Despite this there is still a loud thud/knocking noise every time it goes in. I've tried replacing the valve and also drilled a small hole in the line by the pump to release air. Still hasn't helped. The rise is about 10 ft from pit bottom to horizontal line in ceiling. Any suggestions? The check valve is located about 4 ft above the floor so about 6 ft or so from pump.
Phickman1 is offline   Reply With Quote
Old 01-23-2017, 04:45 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 2,040
Re: Check Balve on Sump Pump
You might be just getting a hammer noise from the piping flexing. By the sounds of your post, you have 10' of (probably) ABS pipe with a pump essentially hung on the end. If yours is like most installs, that pipe is likely unsecured for its whole run and will flex when the pump shuts off and the valve closes.
lenaitch is offline   Reply With Quote
Old 01-23-2017, 04:56 PM   #3
Rewards Points: 36
That probably sounds about right. I did secure the pipe with brackets within the sump closet, but probably wasn't in the ceiling. Good thing is I can access the line in the ceiling which is in between my upper and lower levels that has no insulation to deal with. Thanks
Tags
check valve , sump pump
Sump pump check valve, on pump or spliced in pipe? ponch37300 Plumbing 1 06-18-2016 12:26 PM
Help with Sump Pump Issue (Drainage as well) neverlandpirate Plumbing 2 12-30-2015 07:57 AM
Sump pump check valve help carbocaine Plumbing 2 12-14-2015 06:30 AM
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 06:51 PM
Sump pump large draw of power BlueBSH Electrical 1 03-16-2011 10:51 AM
