Cheapest Way To Fix This Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-27-2016, 09:10 AM   #1
Rewards Points: 62
Cheapest way to fix this shower
I have an extra bathroom that the shower is not being used. The hot water valve broke and was stuck on so I had to remove the whole thing and cap the water lines. I had someone tell me they would fix it for $500 but I would like to attempt it myself. I would guess I need a new shower insert, how much in parts do you think this would cost? I have access to the water lines in a closet behind the tub. Any tips/suggestions would be much appreciated.
mclld is offline   Reply With Quote
Old 04-27-2016, 12:16 PM   #2
Rewards Points: 3,202
Re: Cheapest way to fix this shower
Shouldn't be too much to fix. 500 dollars sounds very reasonable to have someone fix it to me. Does that include parts, material, and labor? Just make sure it's not some hack job.
If you have the skills and knowledge to diy; Looks like your standard tileboard from the big box stores. You may have to replace all the tileboard if you can't get it to match. No biggy. You would probably only need 2 or 3 pieces, about 20 -30 dollars a sheet.
You have access to the water lines so plumbing will be easy. You need a new shower valve and faucet. Remove and replace all that old caulk and redo it right this time, it will look so much better. Depending on your make and brand of shower/tub faucet, I'd guess about, 250-300 dollars in parts and material. Just my opinion.
Please wait for the plumbers to respond. They do these kind of things everyday. Thanks.
jmon is online now   Reply With Quote
Old 04-28-2016, 04:01 PM   #3
Rewards Points: 62
I removed the tileboard and this is what was behind it
Old 04-28-2016, 04:18 PM   #4
Rewards Points: 18,760
There's nothing cheap about fixing this one.
This has been an ongoing problem for a whole that was allowed to go on far to long.
Time for a total gut and redo.
ChiTownPro (04-28-2016)
Old 04-28-2016, 04:28 PM   #5
Rewards Points: 62
I would really like to attempt this myslef and this is not a main bathroom so I can take my time. What all would I need to do?
Old 04-28-2016, 05:16 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 31,580
Two options.
1. A whole tub liner that seals down to the tub.
2. The better option would be to remove walls and install concrete board, or other water proof board like shluter Kerdi or wedi, Then apply new tiles.
Old 04-28-2016, 07:16 PM   #7
Jello Wrangler
Rewards Points: 539
Replacing the tile board would be a mistake. That stuff is for looks not wet areas. Stick it on the wall behind the toilet (only if you hate yourself) but never in a wet area.
You need to demo down to studs.
Replace valve.
Install Durock, Kerdi Board, Denshield and waterproof accordingly.
Tile
Grout with Mapei Flexcolor.
If someone offered to "fix" for $500, loose their number. They know less about it than you do.
ChiTownPro is offline   Reply With Quote
Old 04-28-2016, 11:55 PM   #8
Rewards Points: 744
Replace valve.
Tile
If the plumber offered to fix the plumbing for $500, I don't see what's wrong with that.... If the plumber offered to fix the plumbing and do a full reno, then yes,,,,i'd question that, but that's obviously not what the OP said.
Seattle2k is offline   Reply With Quote
Old 04-29-2016, 07:24 AM   #9
Jello Wrangler
Rewards Points: 539
What plumber? I don't assume or add detail to what has been said.
Read the op. No mention of a plumber or a bid/quote. OP stated "someone" "offered" to fix it for $500. That's not the same as a plumber quoted me $500.
Second, do you understand what is involved in this fix? Could you fix it? If not, then having an opinion on the fix, the cost of the fix and what needs to be done is pointless.
The OP stated that he figured her needed to but a new insert right after saying someone offered to fix it. I reasoned that that was included in the "fix" as its the first thing he listed after that statement. So I would have to conclude the $500 was to fix the valve and resolve the issues with the surround.
Old 04-29-2016, 08:05 AM   #10
Man of many hats
wrangler's Avatar
Rewards Points: 354
What exactly do you WANT to do? Replace the entire unit? You mentioned shower insert. Are you wanting to take out the tub and convert to shower only? All of it can be diy but there are many options as to how it can be done. How much help do you have? if none, that's ok too, just changes procedure a bit ( as in, if no help, it would be easier for you to bust the old cast iron tub with a sledge hammer rather than try to take it out whole, especially if it is not on the main floor). Some people love cast iron tubs, some hate them. It's your bath, so your choice. Of course, budget has a bearing on your decision, but if you DIY you can take your time and save money. And you definitely came to the right place to get advice since after all, this is a DIY Chatroom.
Man of many hats
wrangler is offline   Reply With Quote
Old 04-29-2016, 10:39 AM   #11
Rewards Points: 62
I Would like to keep the tub and just get a functional shower again, so it seems going by what I have read I need to tear down to the studs which is fine. I have never done anything like this but would like to try.
Old 04-29-2016, 03:23 PM   #12
Breakin' Stuff
Rewards Points: 1,374
With time, patience, google, and youtube, you can definitely do this. ChiTownPro listed the basic steps. Also you will have a MUCH better end product this way.
Renovations to my 1947 home can be followed here: www.schlosserhouse.com
Bret86844 is offline   Reply With Quote
Old 04-29-2016, 03:34 PM   #13
Rewards Points: 62
I am not sure about where the transition from the tiles in the rest of the bathroom and the shower tiles meet though, I am guessing I can put some kind of divider in place
Old 04-30-2016, 12:54 AM   #14
Rewards Points: 2,948
While you have referred to a "shower", the photo shows only where the taps/faucets and a "spout" for the BATH previously existed. (i. e. There is no indication of a previously existing SHOWER.)
Replace valve.
Tile
However, to install a shower you need to do much more than "Replace valve"
At least you need to install either a "Riser Bath and Shower Assembly" like this one https://2ecffd01e1ab3e9383f0-07db7b9...d5f1368866.jpg
or a Bath/Shower diverter valve/tap/faucet.
However, there are many other devices that you could use, which may include mixer valves and hand-held/adjustable showers.
Check "riser bath and shower" for images - While most of these show external plumbing, such plumbing can be placed within the wall(s) if you wish.
There is another consideration in that it is a good idea NOT to have the shower "Head" above the faucets that control it, but to place it to the side (for which you do not have room) or on the wall to the right. (Of course, this is NOT the cheapest option.)
You will also need to install a shower-screen (or, at least, a shower curtain.)
This suggests that you intend to re-tile only one wall - which raises questions about "waterproofing" the vertical junction between that wall and the others.
However. If you cannot now purchase matching tiles, just purchase tiles of the same size of a corresponding or contrasting colour and make the repaired wall a "feature wall".
Of course, if you do move the shower head onto the side wall, it will be necessary to repair/re-tile that wall also.
The existing silicone at the wall junctions and along the edge of the bath is poorly done. The wall silicone will be removed when you re-sheet and that along the bath should be cut-out and replaced. However, if you cannot remove every trace (and there are potent chemicals to do this), new silicone will not stick to the old. You could use a white or coloured acrylic sealer instead.
FrodoOne is offline   Reply With Quote
Old 04-30-2016, 07:34 AM   #15
Rewards Points: 374
Thanks for clarifying the what the $500 was for. Way too little for a complete fix, pretty standard for fixing the plumbing. You should be able to get all the plumbing tools/supplies for under $150.
Supplies:
1/2" inside+outside diameter fitting brush
1/2" pipe cutter
Plumbing torch
Solder wire
Flux
Flux brush
Eye protection
1/2" copper pipe (5' should do)
1/2" elbow fittings as needed
1/2" straight fittings as needed
1/2" 90 degree drop ear elbow
1/2" stop valves (optional but recommended; you can also buy a shower valve with built-in stops). Since you need to replace the liner, you can plumb whatever type of shower valve you want.
Shower valve (depends on shower trim selected...some trim comes with correct valve)
Watch a bunch of videos on how to sweat pipe. It's not hard. Always dry fit first.
As recommended, tear that stuff out to the studs. Consider replacing that tub with something less blue while you're at it. It's difficult to tell you exactly what to do, but you're going to build something that looks like what you see in the pic.
Shut off the water main.
If you're installing shutoff valves, connect them on the supply lines before the valve. Test the shutoff valves before proceeding to the next steps. If they work, you can leave them closed and turn the water main back on. Feel free to drink a beer and procrastinate for a week...you've earned it.
Assemble the rest of the system as required for your situation. Read
and carefully follow the shower valve instructions. This will include removing anything with "meltable" parts from the valve housing before sweating. Once everything is soldered, assemble the valve, turn it to the off position and test it. If it works, congrats...you just roughed in your shower and saved hundreds of dollars!
costgeek is offline   Reply With Quote
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 10:20 AM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
