Changing Stem And Seat - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-31-2016, 05:40 PM   #1
Rewards Points: 8
Changing stem and seat
I bought a home last summer and I'm having fun trying to figure out all the little things for the upkeep of the house. Next project is fixing this leaky faucet in the shower. Not sure what brand this is but the guy at Home Depot told me that I have to remove this face plate to pull out the stem. I can't seem how to figure that out. The knob pulls off easily, but the crank beneath it doesn't. Also, no screws or pins anywhere. I'm afraid to pry this off cause I don't want to break it. Can anyone help with taking this apart to pull out the stem?
Changing stem and seat-img_20160320_155647.jpg   Changing stem and seat-img_20160320_155636.jpg
BigDog0 is offline   Reply With Quote
Old 03-31-2016, 05:50 PM   #2
Rewards Points: 3,234
Re: Changing stem and seat
Looks like some build up corrosion around it. Spray some pb blaster on it, let it sit for awhile, give it a few taps and try again. Good stuff imo. Just a suggestion.
If the handle pulled off, I'm guessing the crank will to. If not, there's got to be a way. Someone here will find it.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
BigDog0 (03-31-2016)
Old 03-31-2016, 05:52 PM   #3
Rewards Points: 8
So it really is a matter of just yanking it off? I'm wondering what is binding it to the wall.
Old 03-31-2016, 06:00 PM   #4
Rewards Points: 5,678
I keep a double edge razor blade for jobs like that just in case someone sealed those things to the wall with silicone adhesive sealant. I push the blade with pliers to avoid hurting my old fingers.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
jmon (03-31-2016)
Old 03-31-2016, 06:58 PM   #5
Agree with senior, get a razor blade or box cutter ready, once you get the other handle off the trim may glued or siliconed on there.
Old 03-31-2016, 07:02 PM   #6
I don't know for sure if the handle on the crank just pulls right off or not, just guessing, but that's how the other handle came off. I assume manufacture did the crank handle the same way.
As for the trim plate, follow senior's advice. If there are no screws or that escutcheon in the middle doesn't unscrew and release it, it's probably siliconed or glued on somehow.
Old 04-01-2016, 12:07 PM   #7
Rewards Points: 8
Thanks all. I'm gonna go at it this weekend and report back what happens.
The Following User Says Thank You to BigDog0 For This Useful Post:
jmon (04-01-2016)
Old 04-05-2016, 05:45 PM   #8
Rewards Points: 8
Update: So the short of it is, I didn't do it. I started to pull at the bottom handle but it wouldn't come off. It has been dripping off and on and all weekend, it didn't drip. My wife told me not to worry about it and was afraid I was going to break it so I just stopped. If it gets worse, I'll go at it again.
bob22 (04-06-2016)
Shower valve seat insert Markthenovice Plumbing 0 12-23-2012 08:58 AM
bathtub leaking... seat housing cracked? olnoln Plumbing 12 05-21-2010 01:46 PM
Tub Faucet won't shut off moashalex Plumbing 6 11-24-2009 11:43 PM
Replace Stem sweaty Plumbing 5 11-17-2009 11:48 AM
Bathtub faucet stem seat is frozen and won't turn. Husky Plumbing 1 04-01-2009 01:35 PM
