Changing Out Water Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2017, 08:40 AM   #1
Rewards Points: 4
Changing out water lines
Good Morning,
I have a 100+ year-old home that has had multiple sets of hands on its plumbing over the years. I want to upgrade it all to PEX (HOMERUN) this summer. I've been looking online and multiple threads on this forum for ideas. I have a few questions tho.
This is what I currently have. I also have a picture of what I think I need so far.
http://imgur.com/a/to9g9
I want to clean that all up and put it what's required (or recommended). I see that normally pressure tanks have tees on them with pressure release valves, pressure gauges and a outlet(spigot).
My final goal would be to have from my well pump to every fixture new. 3/4 inch pex from well pump to pressure tank (with replaced tee). 3/4 inch from pressure tank to new water softner + hard water manifold for outside spigots. 3/4 inch from water softener to cold water manifold and hot water heater. 3/4 inch from water heater to hot water manifold. 1/2 lines from cold/hot water manifolds to each fixture in home.
1. Can I replace the line from my well pump to my pressure tank 3/4 inch pex?
2. I see people with nice drawings/layouts of their homes. Is there a recommended program/app for that?
3. My water heater is 10+ feet away in my other room. Would this be a good time to move things closer? Does it have any advantages?
4. Have a Culligan MRK 89 want to replace with https://goo.gl/OVVXYk Morton 34,000 grain Model Number: M340012. Any recommendations for or against? My Culligan Softener is constantly draining and culligan told me it would be 100+ to fix it.
Thanks in advance.
If you need any more or less info let me know.
louisdepre is offline   Reply With Quote
Old 04-06-2017, 04:24 PM   #2
Rewards Points: 144
Re: Changing out water lines
1- City boy here so I can't really talk about the well arrangement. However, going by logics, if your pump doesn't go above 120PSI (I hardly believe it would) then PEX would be no problem.
3- Other than getting it tidy, I don't see why...
4-Seems like a no brainer to get a new one.
GASCo is offline   Reply With Quote
Tags
diy , pex , plumbing
Bonding multiple, separate copper water lines dave11 Electrical 12 08-04-2016 05:57 PM
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Air in hot water lines (well system) John_H Plumbing 3 04-29-2012 10:05 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
