Changing Out This Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2015, 08:07 AM   #1
Rewards Points: 48
Changing out this faucet
I would like to replace this faucet with a new one since it's very old, leaking and I found a lot of rust when I took the handles off. My question is are the hot and cold connections soldered on? What is the best way to change this out with the same exact faucet? Thanks for your input
Mti50 is offline   Reply With Quote
Old 01-28-2015, 08:32 AM   #2
Rewards Points: 3,430
Yes. It appears to be soldered. Shouldn' t be too hard to match up a faucet that will work.
Do you have soldering skills or do you need to go a different route.
jmon is offline   Reply With Quote
Old 01-28-2015, 09:17 AM   #3
Rewards Points: 48
I have never soldered before but know a lot about it, and am very handy/mechanically inclined. What would be your recommendation?
Old 01-28-2015, 09:57 AM   #4
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,688
Originally Posted by Mti50 View Post
I have never soldered before...
It's a tight spot to be learning in (plus the paint & plastic).
Old 01-28-2015, 10:28 AM   #5
FIDO...
Rewards Points: 323
Last spring, I replaced my similar-looking laundry faucet, but I was dealing with plain copper supply lines & plenty of working room, so it was a very easy swap.
If your existing faucet isn't a Central Brass model, then I still bet almost anything that one of these (link) will work as a replacement.
I agree with Tarheel that this would be a very challenging first-time-soldering situation, and I don't think a compression fitting would work here, given the condition of the pipe (older, painted, etc)... Can you perhaps get behind that wall to replace more of the supply lines from back there? Understandably, that may be a long shot...
Otherwise, this particular installation is probably best to call a pro in on.
Cheers, chris
Chris130 is offline   Reply With Quote
Old 01-28-2015, 07:03 PM   #6
Rewards Points: 48
All good information thanks, I suppose you guys are right, I guess I'll get my soldering skills up to speed before tackling this project. Thanks for the recommendation Chris that is exactly what I am looking for, I don't have access to the supply lines without creating a much bigger project.
The Following User Says Thank You to Mti50 For This Useful Post:
jmon (01-28-2015)
Old 01-28-2015, 08:04 PM   #7
Lord of Slums
Rewards Points: 1,974
When possible I rebuild those faucets.
mj12 is offline   Reply With Quote
Changing faucet - reverse osmosis adapter grand_canyon Plumbing 4 11-20-2012 10:29 PM
Pressure loss throughout house after changing faucet smh73 Plumbing 5 06-05-2011 12:59 PM
Selecting a New Kitchen Faucet klumbsy Kitchen & Bath Remodeling 4 02-25-2011 08:29 AM
Faucet not changing temperature ctrealestate Plumbing 4 10-08-2009 03:39 PM
Opinion needed about changing kitchen faucet chris_p Plumbing 11 02-01-2009 10:39 PM
