Changing Moen Positemp Cartridge Without Turning Water Off - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By hkstroud
Old 11-05-2017, 05:50 PM   #1
Rewards Points: 86
Changing moen positemp cartridge without turning water off
Hi
Is it possible to change the moen positemp cartridge without turning the water off?
I have a one handle two function faucet. (no pulling)
https://www.homedepot.com/p/MOEN-Ali...91BL/301977532
Would worst case scenario be wet feet? Because I can wear shorts and no socks. Much easier than having to go into another unit of a duplex and shutting off the water.
Thanks!
bartonst is offline   Reply With Quote
Old 11-05-2017, 06:03 PM   #2
Rewards Points: 18,972
Re: Changing moen positemp cartridge without turning water off
Not going to happen.
I'd spend some time figuring out if there was another shut off some place.
It just would make not make since they did not allow for this when building this unless this was a condo conversion.
Your going to have at least 40 PSI of pressure blowing out of that wall.
bartonst (11-05-2017)
Old 11-05-2017, 06:15 PM   #3
Rewards Points: 86
Ok thanks for letting me know. It's just a duplex. Water meters in the basement and this is the upper unit. Don't think there's another shut off upstairs but will check.
I have the tenant moving out and the shower cartridge is installed upside down. Person I bought the house from owns/operates mechanical piping and Hvac construction company.
They must do amazing work.
Old 11-05-2017, 07:21 PM   #4
Naildriver
chandler48's Avatar
Rewards Points: 3,554
When looking in the hole where the valve is, do you see two large flat head screws? If so, you can turn them across the pipe and shut off the water to the valve. If you don't have them, then road trip time.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Old 11-05-2017, 07:29 PM   #5
hkstroud's Avatar
Rewards Points: 6,694
What does that mean?
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 11-05-2017, 07:48 PM   #6
Rewards Points: 86
Yep! I just read about that before posting. Not sure if i have those. Many thanks for the info. If it resorted to having to adjust those, I probably won't do the job. I'm a newbie and it would get to that point of should i attempt to fix something that's not broken (only a nuisance) and risk breaking something else. Because that's the way she's been going lately
Old 11-05-2017, 07:49 PM   #7
Rewards Points: 86
instead of pulling the handle up you push it down and go the other way. lazy idiot installed it. he would have probably turned the handle once he finished and realized it was wrong.
Old 11-05-2017, 07:53 PM   #8
Naildriver
chandler48's Avatar
There's no adjusting, just turn the screw head vertical and it turns off the water to the control valve. When you are through, turn them horizontally and it will turn the water back on.
To further Harold's comment which I missed on your second post. The cartridge is in upside down? Sometimes it is necessary to correct backwards piping. Does it not work properly....ie. cold to hot?
Larry......
Old 11-05-2017, 07:56 PM   #9
Rewards Points: 86
yes it works properly.. just have to turn the handle clockwise. two sets of tenants now never cared. tenants don't care about a lot of things.
Old 11-05-2017, 08:04 PM   #10
hkstroud's Avatar
If valve is installed upside down that won't work. You will have to remove the valve and reinstall it correctly.
Notice the UP encircled.
Changing moen positemp cartridge without turning water off-moen-mixing-valves-2510-e1_1000.jpg
chandler48 likes this.
Harold,
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Moen 1225 cartridge replaced - can't turn off water sayzme Plumbing 5 10-14-2014 11:25 PM
Shut off water to replace Moen single shower handle? operagost Plumbing 6 03-25-2013 09:34 PM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 04:47 PM
