Changing Faucet Cartridge Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2015, 11:04 AM   #1
Rewards Points: 28
I have a JADO single lever faucet. Need to change out the cartridge.
I had done it once before when it was newer, and it seemed to be easier to remove the cartridge retaining brass nut. Probably because of water mineral buildup and such. The difficulty is that the nut is set slightly lower than the top of the cartridge cavity. I believe that I used a smooth face channel locks before with no problem. This time it is little more difficult, and I slightly rounded the top of the nut in the process. I am wondering whether I can get a deep socket plug on top of that. I am trying to figure out what size it is. I am guessing a 21mm, as it is metric. Anybody have an idea? I don't have anything to measure it with. By the way, is it difficult to get these replacement nuts? Or do I have to go back to the company to get it? If so, they claim that it is not a replaceable part!
Hoshwa is offline   Reply With Quote
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
New Moen Cartridge Is Still Leaking on Bathtub faucet rliu Plumbing 7 01-14-2013 08:49 AM
Help IDing mini-widespread faucet cartridge Learning Lots Plumbing 0 09-17-2011 05:05 PM
how to recognize the new or old bathtub faucet cartridge jeand Plumbing 2 12-18-2010 01:27 PM
Faucet Cartridge removal -- what should I have done? RippySkippy Plumbing 9 08-20-2009 08:49 AM
