Catch Basin Options (Yard) - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-05-2017, 03:45 PM   #1
Rewards Points: 20
Hi,
I need to install a catch basin for this yard drain. Should I use this Lowes sink basin, and change the pipe end to straight from 90 degree? If so how do I do that - hacksaw off the at the current joint and add an short length?
bigpig is offline   Reply With Quote
Old 03-06-2017, 04:58 PM   #2
Rewards Points: 704
Re: Catch Basin Options (Yard)
Not sure why there is a clean-out installed. Is that what it is....and what is the area being drained ?
Cedrus is offline   Reply With Quote
Old 03-06-2017, 07:16 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,218
Ayuh,... Lotsa styles of catch basins,...
Where does that pipe go too,..??
Old 03-06-2017, 07:56 PM   #4
Rewards Points: 20
Yep, that is a clean out. The area being drained is a patch of soil in front of a house.
Old 03-06-2017, 07:59 PM   #5
Rewards Points: 20
yeah, what I mean't to ask was how to connect them - I bought the Lowes on linked and in order to get a sealed connection need to remove the 90 degree bend section - how do I do that?
Pipe goes to storm drain in road I think, although we haven't found it yet...
Old 03-07-2017, 05:30 AM   #6
Bondo's Avatar
Ayuh,.... Cut it off with a saw,...
First Home First Yard First Spring cjlmparker Landscaping & Lawn Care 0 03-16-2013 02:19 PM
Back yard redo - Weeds out of control carquote Landscaping & Lawn Care 6 03-03-2012 08:24 PM
Severe Drainage Issue kirridam Landscaping & Lawn Care 11 07-25-2009 06:44 AM
Yard Advice Please - Lots of Weeds! Myrkur Landscaping & Lawn Care 7 06-15-2009 09:41 PM
Catch Basin sebas54 General DIY Discussions 2 07-13-2008 09:38 PM
