Cast Iron Pipe - Made In USA - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree5Likes
  • 1 Post By ct18
  • 4 Post By joed
Old 10-20-2017, 08:25 AM   #1
Rewards Points: 48
Cast Iron Pipe - Made in USA
I am having my main waste pipe replaced from inside foundation wall out to sewer main in the middle of the street because there is a break in the pipe. Have received several quotes from contractors. Some specify whether they will use cast iron pipe that is specifically Made in USA. Others don't have a specification, and when asked they say there are pros and cons to Chinese, Japanese, and US-made pipe.
Is there any real difference I should be concerned about? Is US-made of significantly higher quality?
I do not want to have to dig up the ground again in 10 years because the pipe has failed. So, long life and durability are most important.
This is in Philadelphia, for a row house. Configuration is similar to the image at the link below, except my waste pipe exits the foundation at the same level as the slab, and I won't have a backwater valve.
http://www.phillywatersheds.org/img/backwater_valve.jpg
Thanks in advance!
cb_philadelphia is offline   Reply With Quote
Old 10-20-2017, 10:38 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,368
Re: Cast Iron Pipe - Made in USA
Seeing as most of the overseas steel is based on our technology and in many cases, from factories that we built....I think you are fine either way.
The installer and company is going to be the bigger differentiator here.
Old 10-20-2017, 12:19 PM   #3
Rewards Points: 781
Tyler Texas, Tyler cast iron pipe. I don't see why it would cost more we use it on large projects all the time.
TheEplumber likes this.
ct18 is online now   Reply With Quote
Old 10-20-2017, 12:41 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,970
Is it a local code to use cast iron? I would use PVC or ABS drain pipe.
Bondo, joecaption, Yodaman and 1 others like this.
Old 10-20-2017, 04:40 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 258
Ditto. No reason to go elsewhere. IMO, they they are the leaders for CI plumbing products.
replacing broken cast iron pipe in crawl space mrkapasi Plumbing 13 01-27-2016 04:13 PM
Cutting cast iron waste pipe kxweil38 Plumbing 3 03-09-2015 09:50 AM
Cast iron drain pipe replacement riedej Plumbing 3 05-09-2012 12:56 PM
Build up in cast iron pipe bend -> new high pressure toilet to fix? VTJeff99 Plumbing 3 02-09-2012 01:05 PM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 05:39 PM
