Cast Iron Floor Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2015, 03:31 PM   #1
Rewards Points: 396
Cast Iron floor drain
I need to cut off my existing cast iron basement floor drain grate and I'd like to replace it with PVC. Do you they make adapters for this?
detroittigerfan is offline   Reply With Quote
Old 12-09-2015, 03:38 PM   #2
Rewards Points: 5,348
Is this a square iron piece recessed into the concrete? Photos will help.
Is the drain connected to a pipe or is it just a place for water to empty into a dry well?
Ron
B. Franklin 1759
Old 12-09-2015, 03:52 PM   #3
Rewards Points: 18,988
Why's it need to be cut off?
Willing to bust out the concrete enough to use a Furnco adapter to adapt?
Old 12-09-2015, 05:04 PM   #4
Rewards Points: 396
no its a 3" round pipe. Its connected to the sewer. Don't they make PVC adapters?
Old 12-09-2015, 05:04 PM   #5
Rewards Points: 396
The grate is rusted on the pipe and it won't come off unless I cut it off.
Old 12-09-2015, 05:49 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 278
Floor drains usually consist of a drain body that is embedded in the floor and the grate is attached to it. This makes removal next to impossible unless you tear into the floor.
There is a possibility that you have a push on grate and replacements are likely available. But even these may require a slight amount of concrete demo.
I can't give more suggestions without seeing it though.
Old 12-09-2015, 06:15 PM   #7
Rewards Points: 396
Why could't you remove the grate using an angle grinder and then use a pvc donut inside the existing cast iron?
Cast Iron to ABS - What Coupling? Jaxx Plumbing 1 09-17-2014 05:16 PM
Tying laundry tub into old cast iron drain tigeraid Plumbing 4 02-13-2013 02:17 PM
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 04:41 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
