Cast Iron Fernco Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-10-2018, 03:41 PM   #1
Rewards Points: 14
Cast Iron Fernco help
Hey Gang,
I donít have enough room to adapt to adapt to PVC so I went with No-Hub Cast Wye.
The issue is my 4Ē fernco are too small for the 1900ís extra heavy cast iron.
See the images for a circumference comparison with a guide wire.
What do I do? Does fernco make an adapter for extra heavy or can I get a different Wye that is thicker?
Thanks,
djfremen is offline   Reply With Quote
Old 03-11-2018, 11:17 AM   #2
Rewards Points: 1,938
Re: Cast Iron Fernco help
uSE A PROFLEX BAND COUPLING THAT IS MADE FOR HEAVY CAST IRON.
The Following User Says Thank You to Ghostmaker For This Useful Post:
djfremen (03-11-2018)
Old 03-11-2018, 11:43 PM   #3
Rewards Points: 14
I found some shielded Fernco that work!
Old 03-12-2018, 06:12 PM   #4
That will work
pvc to cast iron hub using fernco-can't get it! What have I done Plumbing 11 03-25-2020 01:32 PM
Tapping into main cast iron line using Fernco tripower Plumbing 9 11-26-2013 07:48 PM
Attaching a Fernco to a Cast Iron Elbow Fisher252 Plumbing 5 07-18-2012 10:30 AM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 05:39 PM
