Cast Iron To ABS Conversion - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-13-2016, 09:39 PM   #1
Rewards Points: 299
cast iron to ABS conversion
I need to change the vent line for my kitchen sink. No real problem, but I'm wondering how to handle the hub coming out of the slab. The vent is 2" cast iron. The house was built in 1965. It looks like the 2" cast iron is stuck into the hub and hot lead poured around it.
Can this hub accommodate ABS pipe via some sort of conversion fitting, or will I need to have a small length of cast iron fitted and then convert to ABS?
Images attached. Thanks for your input.
Well, even rotating and re-uploading the images don't give me proper orientation. Should be portrait. I guess cell phone images for uploading need to be shot in landscape.
Bob... is offline   Reply With Quote
Old 05-13-2016, 10:41 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 186
Re: cast iron to ABS conversion
What you need to do is drill out the lead with a small bit- like 1/4" Drill a series of holes around the pipe. Clean out the remaining lead with a screw driver.
Be careful to not apply too much pressure on the hub- it might snap off- then your into plan B...
Once the lead is out, the oakum packing is the next thing to remove. This can be done before or after the pipe is lifted out of the hub- it can be tough to pull out.
Clean out the hub real good and insert a doughnut like this- https://www.fernco.com/plumbing/donuts-o-rings/donuts
Use ABS or PVC pipe
Rotated images--
The Following User Says Thank You to TheEplumber For This Useful Post:
Bob... (05-13-2016)
Old 05-13-2016, 10:50 PM   #3
Rewards Points: 299
Thanks very much. Exactly the info I needed. Thanks also for rotating the images. .
The Following User Says Thank You to Bob... For This Useful Post:
oh'mike (05-14-2016)
Old 05-14-2016, 07:54 AM   #4
Rewards Points: 299
I guess I should also have asked: Any additional special tips or tricks to getting the lead and oakum out and cleaning the hub? Would a heat gun help, or would that increase the likelihood of plan B?
Replacing cast iron sewer pipes with pvc? kyle.arcand Plumbing 6 02-23-2013 08:59 PM
Tying laundry tub into old cast iron drain tigeraid Plumbing 4 02-13-2013 02:17 PM
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 04:41 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
