Capping Off An Old Sewer Line Under Concrete - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2018, 10:22 PM   #1
Rewards Points: 8
Capping off an old sewer line under concrete
As part of a basement project, I may need to relocate a stretch of 3" ABS sewer line so that it intersects with the main sewer line about 2 feet upstream from where it currently intersects.
My plan is to leave a length of the old 3" sewer line in place (about 18" or so) and cap it off by connecting it to a short piece of 3" PVC pipe with a Fernco coupling. I will then solvent weld a PVC cap to the end of the PVC pipe, and bury the whole thing in cement.
Is that plan code compliant?
cdet1997 is offline   Reply With Quote
Old 01-05-2018, 08:18 AM   #2
Guapo
Rewards Points: 11,950
Re: Capping off an old sewer line under concrete
Codes are local not that anyone is going to know what you did since it won't be seen. I would ask a local plumber.
Guap0_ is offline   Reply With Quote
Main Sewer line is disjointed and offset cprao Plumbing 33 12-26-2013 07:56 PM
Sewer Line backing up...Argh! Demianwulf Plumbing 38 10-31-2013 10:07 PM
NEED ADVICE: Mystery water near sewer line tripower Plumbing 9 10-22-2013 11:31 AM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 11:19 AM
Sewer Line Continues to clog. Just Some Guy Plumbing 16 08-24-2009 10:38 PM
