Capping ABS Drain - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
Old 10-03-2016, 04:46 PM   #1
Solidify's Avatar
Rewards Points: 834
Capping ABS Drain
We're going from a double sink vanity to a single one like this:
Name:  ImageUploadedByDIY Chat1475531053.316713.jpg
Which means we need to cap and recess the two supply lines and the drain pipe for the second sink and then patch the drywall.
Am I supposed to use a solvent cap or one of those blue poly test caps for capping the black 1 1/2" ABS drain pipe? How do you know when to use one over the other? The drains will not be accessible afterwards and tiled over.
Solidify is offline   Reply With Quote
Old 10-03-2016, 05:44 PM   #2
Rewards Points: 18,796
Re: Capping ABS Drain
Not sure how anyone would know without a picture of under the sink.
Most often you would jut replace the whole thing from the wall out, no caps needed.
Old 10-03-2016, 05:48 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,048
Ayuh,.... It's All "T"ed together behind the wall,..?? Right,..??
Insteada cappin' the business ends, replace the "T"s in the side yer continue to use,....
Bondo is online now   Reply With Quote
Old 10-03-2016, 05:52 PM   #4
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,682
Test caps are for temporary use. Solvent weld anything permanent.
But, as stated above, get rid of the extra pipes properly.
123pugsy is offline   Reply With Quote
Old 10-03-2016, 08:58 PM   #5
Solidify's Avatar
Rewards Points: 834
What difference would it make if I'd just cap the Ts as opposed to replacing them with straight couplings, if the wall will be closed?
Old 10-03-2016, 09:58 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 180
Makes no difference. Cap them with permanent caps as close as practical to the tees.
MTN REMODEL LLC likes this.
The Following User Says Thank You to TheEplumber For This Useful Post:
MTN REMODEL LLC (10-03-2016)
Old 10-04-2016, 08:12 AM   #7
Solidify's Avatar
Rewards Points: 834
Capping ABS Drain
I dont trust my soldering skills enough so I was going to glue an ABS cap but use two sharkbite caps for the copper.
Old 10-04-2016, 01:06 PM   #8
Solidify's Avatar
Rewards Points: 834
Capping ABS Drain
This is what I'm working with:
There isn't enough room to pull the hot line off the 2x4 to get my mini cutter in there.
Old 10-05-2016, 02:12 PM   #9
Solidify's Avatar
Rewards Points: 834
Capping ABS Drain
Plumber came. I asked him to replace the T's with couplings but he kept insisting that it's not necessary:
The Following User Says Thank You to Solidify For This Useful Post:
Ghostmaker (10-05-2016)
Old 10-16-2016, 09:23 PM   #10
Rewards Points: 271
Plumber burned your wood.
Druidia is offline   Reply With Quote
Old 10-16-2016, 11:23 PM   #11
hkstroud's Avatar
Rewards Points: 6,684
Agree. Considerably more work and would have taken a lot longer and cost you more.
Yes, pretty sloppy for a pro.
hkstroud is offline   Reply With Quote
Old 10-29-2016, 02:38 AM   #12
Solidify's Avatar
Rewards Points: 834
He was here for 15-20 min max and asked 80$. Is that fair?
Old 10-29-2016, 03:41 AM   #13
Rewards Points: 1,414
If it was worth it to you and you agreed to it, it's perfectly fair. Or at least it's a fair exchange of money for time, although arguably you were paying for skilled time and not for burning your wood like that.
Whether it is competitive (in cost, professionalism, quality, and responsiveness) depends on your market.
Tom738 is offline   Reply With Quote
Old 10-29-2016, 05:30 AM   #14
123pugsy's Avatar
Yes, fair.
$80.00 usually just covers traveling time. There is usually another one hour minimum tacked on and a 15-25 dollar truck charge as well.
Old 11-03-2016, 07:52 PM   #15
Solidify's Avatar
Rewards Points: 834
Originally Posted by 123pugsy View Post
Yes, fair.
Since when are we supposed to pay for a tradesman's travelling time? If the guy takes 6 hours to fix something, aren't I supposed to pay him those 6 hours, or at the the very most, 6.5 hours if he needed to go the store for parts? I didn't know I need to pay the guy from travelling time too... is this the norm?
One hour minimum I can relate to, so the job isn't pointless or not worth it for them.
What's a "truck charge?"
Trane XE80 - Drip pan filling up. Drain setup wrong? Please help :) Mognar HVAC 5 06-09-2014 10:52 PM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Tying into 50's style clay drain tile perimiter system/exposed Pit / Wall membrane alecmcmahon Plumbing 6 12-29-2010 07:23 AM
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 10:40 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
