Cap Off Old Drain In Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-29-2016, 07:02 PM   #1
Rewards Points: 244
Cap off old drain in floor
We put in a floor drain years ago (picture attached) for the washer/dryer that we used. We remodeled the the space and now we need to cap off the drain as we're installing a vanity in its place. It's a 2" drain so sticking a piece of 1 1/2" ABS pipe with a lot of rubber cement and a 1 1/2" cap looks to be the easiest solution. The problem is the cap sticks out above the floor which gets in the way of the vanity. How can we cap off this drain so it sits as recessed as possible when installed (yes, we're going to cut off the lip for the grate with a multi tool)?
anuvanoob is offline   Reply With Quote
Old 12-01-2016, 08:18 AM   #2
Rewards Points: 1,054
Re: Cap off old drain in floor
Glue in a threaded fitting and use a flat cap with some pipe dope on the threads.
clarenceboddick is offline   Reply With Quote
Old 12-01-2016, 08:28 AM   #3
Rewards Points: 1,994
Where does that floor drain connect? Does it go to your perimeter foundation drain or into your sewer drain?
Bud
Bud9051 is online now   Reply With Quote
Old 12-01-2016, 12:23 PM   #4
Rewards Points: 244
Sewer drain. Someone went ahead and capped it off by dropping a screw cap in stuffing fix all or something on top of that. Not the way I wanted to do it, but hopefully that's good enough
Sent from my Nexus 6P using Tapatalk
Old 12-01-2016, 01:49 PM   #5
Well sounds like it's too late, but if that goes to where there is sewer gas the sealing method needs to be absolute and there may be code requirements.
Bud
Older home with floor drain - how to keep water out? b-boy Plumbing 14 12-03-2015 06:10 PM
Adding a floor drain in concrete ponch37300 Plumbing 5 10-29-2015 09:50 PM
UPC drain requirements for 2nd floor water heater keymaster Plumbing 4 10-04-2015 06:04 PM
Engineered hardwood over vinyl tile - am I being unreasonable or am I getting screwed photopeter Flooring 25 02-01-2014 11:41 AM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
