Cant Use Plumbers Putty On Faucet Base. Ideas? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2015, 08:09 AM   #1
Rewards Points: 1,062
Cant use plumbers putty on faucet base. Ideas?
Have an 8" bathroom faucet, a one piece unit, and the base of it does not have a nice flat "platform" or surface area where one could put a bead of plumbers putty on it and "seat" it down on sink. Can one simply place the bead on the knife edge and seat it down creating a good seal? Looks like that is a bad way to do this.
Called home depot and they do not sell seperate black plastic bases/gaskets. What could I do, people?
thanks
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 02-01-2015, 08:43 AM   #2
Rewards Points: 3,130
Well, if it were me I'd take the faucet back and exchange it or buy a better one. More than once, I've bought something from HD only to find that the package had been previously opened. It's possible the gasket is simply missing. What do the instructions say?
The Following 3 Users Say Thank You to md2lgyk For This Useful Post:
ben's plumbing (02-02-2015), COLDIRON (02-02-2015), noquacks (02-01-2015)
Old 02-01-2015, 09:21 AM   #3
thanks, md, but its an old faucet- put on years ago, but still in excellent shape. I pulled it up and it had gobs of putty , mostly kicked up inside as like I said, noflat base. I hate to throw it out, and as a last resort, I will gob up putty and try it.
Of course, the base would be like a knife edge.
Old 02-01-2015, 09:34 AM   #4
Plumber
TheEplumber's Avatar
About your only choice is to put a ring of putty around the holes.
If the edge is thick enough use a bead of silicon.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 02-01-2015, 10:20 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 18,422
If it was me, I'd use white silicone.
This is the way I would do it.....
Run a 1/4" bead around the base. Then let it sit until the surface is not tacky...usually about 45min to an hour.
Then put in place and tighten down.
Now clean up what squeezes.
If necessary, touch up.
Let it dry over night.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 02-02-2015, 06:04 PM   #6
Registered User
Rewards Points: 526
Auto parts stores have "make your own gasket" sheets.... get one that is waterproof.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
mj12 (02-02-2015)
Old 02-02-2015, 06:19 PM   #7
Rewards Points: 1,042
They also have liquid Permatex gasket maker,pick yer poison.
http://www.permatex.com/products-2/p.../gasket-makers
Canarywood1 is offline   Reply With Quote
Old 02-02-2015, 07:38 PM   #8
Lord of Slums
Rewards Points: 1,974
Long long ago they would sell small rolls of flat cork. I lay it against the part and lightly hammer the edges. Made hundreds of gaskets like that.
mj12 is offline   Reply With Quote
Plumbers putty or silicone for SS sink seat? noquacks Plumbing 16 05-12-2013 08:35 PM
Plumbers putty and corien sink? Ebierley Plumbing 2 04-23-2013 09:13 PM
Does regular plumber's putty stain quartz? Druidia Plumbing 0 04-18-2013 12:36 PM
Plumbers putty or Silicon Caulk? sukhenkoi Plumbing 2 04-21-2010 06:51 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
