Can't Tell What Would Fit & Plumber Gone - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2015, 08:57 AM   #1
Rewards Points: 16
Can't tell what would fit & plumber gone
Hey guys,
The plumber ran pipe and installed this shower fixture unit. Can anyone tell what brand would fit what he installed? Any thoughts are appreciated, because now the plumber is MIA.
The piece that's not installed is what came with the shower faucet kit.
givemecoffee is offline   Reply With Quote
Old 03-07-2015, 09:51 AM   #2
Rewards Points: 18,952
I'm sure one of the plumbers will be along shortly.
He never should have used steel strapping, it's going to cause corrosion.
Copper or plastic only.
Old 03-07-2015, 11:26 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 240
The top image looks like a moen valve- not sure of the lower one.
Can you supply a closer image of the valve stem in the top image?
If it really is a Moen then you have several trim styles to choose from- see their catalog online
Old 03-07-2015, 12:53 PM   #4
Rewards Points: 582
yep top is moen.....no problem getting a trim kit for that one....
Old 03-07-2015, 02:10 PM   #5
Rewards Points: 38
Unless the top pic is backwards, it appears "plumber" reversed the hot and cold water supplies. Lucky if it is a Moen because that can be easily fixed by flipping the cartridge and not having to re-pipe.
SHR Plumber is offline   Reply With Quote
Old 03-07-2015, 03:15 PM   #6
Rewards Points: 16
Here is a closer picture
Can't tell what would fit & plumber gone-20150307_150613-1_1425762897584.jpg
Old 03-08-2015, 04:12 AM   #7
Rewards Points: 38
As stated by TheEplumber and Ben's Plumbing, you have a common standard Moen Posi-Temp valve body. Lots of trim kits readily available from any plumbing store.
Old 03-08-2015, 11:07 AM   #8
Rewards Points: 16
Thanks so much everybody.
Toilet Install Went Wrong, Poor Plumber Choice pbrigante Plumbing 12 08-10-2014 09:35 PM
Plumber added a Tee to NGL near grill - no valve? mikestorm5 Plumbing 29 03-25-2014 09:59 PM
Dishonest Plumber Left Major [Expensive] Issues ConsumerTalk Plumbing 4 03-27-2011 01:23 PM
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 07:57 PM
HELP! I'm NOT a plumber. And I don't play one on T.V.! kswoot Plumbing 20 10-02-2008 01:14 PM
