Can't Remove Tub Spout - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree7Likes
Old 10-23-2016, 12:29 PM   #16
hkstroud's Avatar
Rewards Points: 6,684
Re: Shower head drips when spout running
wild bill
I can certainly understand you concern about not damaging the pipe.
I suggest that you get out your hacksaw and cut the spout about 1 1/2" from the wall
You of course won't be cutting straight through You will be cutting around the spout. Cutting the outer shell of the spout only. There is considerable distance between the outer shell of the spout and the piping.
There are two types of screw on spouts. One has the screw fitting up next to the wall.
The other has the screw fitting closer to the diverter valve.
If you have the slip on type or the screw on type with the fitting close to the wall, the end of the spout will fall off.
You can confirm which type you have. If you have a screw on type you can use a strap wrench with more confidence to remove.
If you have the screw on type next to the diverter and have a torch you could apply some heat to break the bond. Just make sure that the pipe has cooled (run some water) before trying to unscrew. Hot copper bends easily. If it won't unscrew, cut the spout again just ahead of the fitting, heat the fitting (unsolder)and pull the spout and the male pipe adapter off together.
hkstroud is offline   Reply With Quote
Old 10-23-2016, 12:34 PM   #17
Wildbill7145's Avatar
Rewards Points: 180
Originally Posted by de-nagorg View Post
Wildbill: I had another idea, may be a bit outlandish, but here it is.
You said that you had a replacement diverter/spout?
So take a Dremel with a CUTOFF wheel, and open that slot on the old one wide enough that you can definitely see what is up in there, pry back the "wings" , to get a good sight.
Then you will definitely know if there is a screw or not.
I forgot to mention USE SAFETY GLASSES
Power: I too apologize for using your post to offer Wild my advice.
And The "sparky" thing was hopefully a "just kidding" thing, guess you took it wrong.
I am all for DIY ing, been doing it for 50+ years.
ED
Hmm, could do that. I was just telling the wife I'd be willing to take a hack saw and cut this thing apart to see what's holding it on. Just get a replacement faucet. Thing's made of plastic or whatever anyway. (Edit: Just checked. The shower head's plastic, not the faucet.)
I think my wife has a dremmel. Not sure about a cutoff wheel. I've got a 12amp angle grinder, but I'm sure that'd be a bit much.
Moen sent us these things. Thought they were sending us a brand new faucet, ended up getting these.
Wildbill7145 is offline   Reply With Quote
Old 10-23-2016, 12:55 PM   #18
Rewards Points: 180
Originally Posted by hkstroud View Post
wild bill
That's what I was just talking to my wife about too. Man do I hate doing my own plumbing. Either way I'm not getting into this today. Don't have a torch and if I really wreck something I'm not paying a plumber $200 an hour to have them come fix it on a Sunday afternoon if I can find one that'll do it.
Old 10-23-2016, 12:57 PM   #19
Plumber
TheEplumber's Avatar
Rewards Points: 188
Re: Can't Remove Tub Spout
Moved posts to it's own thread- I hope I got all posts included-
Wildbill7145 likes this.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
de-nagorg (10-23-2016), Wildbill7145 (10-23-2016)
Old 10-23-2016, 12:57 PM   #20
Rewards Points: 180
You're a good man Eplumber from one mod to another (painttalk). Thanks for giving this thing it's own thread.
TheEplumber likes this.
Old 10-23-2016, 03:45 PM   #21
Rewards Points: 180
This might end up being a stupid question, so be prewarned.
So, I stick my mirror under the part of the faucet where the water comes out. Pull up and down on the pin on top that determines where the water goes. I can see both parts that I'm supposing have to get changed out. The ones I posted pics of above.
What are the chances that I can change those parts without having to pull the faucet off? I wonder if there's a way to pull that pin apart to change the white thing and once it's out of the way I could possibly get at the black O ring type thing that goes above it? Maybe I should take a pic of what I'm talking about.
Old 10-23-2016, 04:15 PM   #22
hkstroud's Avatar
Not a snowballs' chance in Hell.
What will happen if you put too much pressure trying to unscrew will be that you twist the copper pipe. The problem then is that you have to go into the wall to replace. Chances of twisting the pipe is not very great is it is a screw off type.
It certainly looks to be a screw off type. No signs of set screw or the collar it screws into in your photo.
As someone else suggested a Dremmel tool would be the best. Faster than hacksaw.
The connection between the spout and the male adapter on the end of the pipe doesn't have to be very tight. There is really very little water pressure on it. So what if it leaks. That's why you have the drain hole.
What probably happened is that BIL had to really crank down on it when installing to get the spout up against the wall.
Its his fault no matter what.
Old 10-23-2016, 06:25 PM   #23
Rewards Points: 180
Lol. As an aside, my wife and I just fixed this albeit possibly temporarily.
Got up in the end of the spout with my Dad's old pocket knife and a pair of needle nose pliars. Got the gate valve out by prying the plastic white piece (pictured above) out by prying the friction fit around the pin piece off with the pocket knife and pliars. The bit Moen sent us totally didn't fit. Way too wide. We're not gonna have a shower for days... Oh no.
Mashed the old black gasket/ring around a bit. Looked fine. Rammed it back in there into the white piece. Put it back in around the pin until it held.
Tried it, and voila! Shower came on first try. Tried it probably 30 times after that and it worked every time!
Now I gotta figure out a way to punish myself for having lived with this thing not working for the past several months. Anyhoo, perseverance is the key.
And the desire for a shower every morning.
Old 10-23-2016, 06:31 PM   #24
Rewards Points: 180
I gotta call someone. A Canadian just made a snowman in hell, and it held!
We know this stuff!
Old 10-23-2016, 08:55 PM   #25
hkstroud's Avatar
We know this stuff!
It is so nice to be wrong.
Congratulations
PS
If your fix doesn't last, you could always lay down in the tub, stick your big toe up the spout and let the wife take a shower.
Old 10-23-2016, 09:24 PM   #26
JUSTA MEMBER
Rewards Points: 3,340
No that won't work.
Stuff a potato up in the spout and shower with her.
ED
de-nagorg is offline   Reply With Quote
Old 10-26-2016, 06:22 AM   #27
Rewards Points: 1,868
Looks like it unscrews.
Old 10-26-2016, 06:33 AM   #28
Rewards Points: 5,704
And for GAWD SAKE, if you ever get it screwed off do not put Teflon tape on the threads for re-assembly so the next person will have the same hell you've had. Just claim you are normal and a slow learner like other folks.
Old 10-26-2016, 06:36 AM   #29
Rewards Points: 10,490
70 above (+19 deg. Celsius): Texans turn on the heat and unpack the thermal underwear. People in Canada go swimming in the Lakes.
60 above (+14 C): North Carolinians try to turn on the heat. People in Canada plant gardens.
50 above (+9 C): Californians shiver uncontrollably. People in Canada sunbathe.
40 above (+4 C): Italian and English cars won't start. People in Canada drive with the windows down.
32 above (0 C): Distilled water freezes. Lake Superior's water gets thicker.
20 above (-6 C): Floridians put on coats, thermal underwear, gloves and woolly hats. People in Canada throw on a flannel shirt.
15 above (-8.5 C): Philadelphia landlords finally turn up the heat. People in Canada have the last cookout before it gets cold.
0 degrees (-18 C): People in Miami all die. Canadians lick the flagpole.
20 below (-26 C): Californians fly away to Mexico. People in Canada get out their winter coats.
40 below (-36 C): Hollywood disintegrates. The Girl Guides in Canada re selling cookies door to door.
60 below (-46 C): Polar bears begin to evacuate the Arctic. Canadian Boy Scouts postpone "Winter Survival" classes until it gets cold enough.
80 below (-56 C): Mt. St. Helens freezes. People in Canada rent some videos.
100 below (-66 C): Santa Claus abandons the North Pole. Canadians get frustrated because they can't thaw the keg.
297 below (-164.5 C): Microbial life no longer survives on dairy products. Cows in Canada complain about farmers with cold hands.
460 below (-246 C): ALL atomic motion stops (absolute zero in the Kelvin scale). People in Canada start saying, "Cold 'nuff for ya?"
500 below (-266 C): Hell freezes over. The Toronto Maple Leafs win the Stanley Cup.
hkstroud and Wildbill7145 like this.
SPS-1 is offline   Reply With Quote
Old 10-26-2016, 04:32 PM   #30
Is the spout still looking down or did you turn the chrome part.
Can't remove old set screw tub spout Chriss538 Plumbing 3 09-23-2012 07:28 AM
Removal of Tub Spout Remski Plumbing 2 09-11-2012 11:09 AM
where do I set the black o- ring on the tub spout? or the threaded copper pipe? radioflyer77 Plumbing 1 07-05-2012 09:23 PM
Leaky bathtub spout alacea Plumbing 0 11-29-2010 12:58 PM
