Can't Remove Toilet Flange. - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-07-2016, 01:38 PM   #1
Rewards Points: 18
Can't remove toilet flange.
Hey everyone, I removed my toilet today because I noticed my anchor bolts were rusty. Long story short I'm going to be replacing this flange. But I can't get the old one out. Strangely, I didn't see any screws originally from when I first removed the toilet. It looks like it is a metal ring around pvc. Very very rusty. Pic related. Thanks everyone
MKMaster is offline   Reply With Quote
Old 08-07-2016, 01:43 PM   #2
Rewards Points: 8,349
Re: Can't remove toilet flange.
Normally they are glued to the pipe and have screws to the floor.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is online now   Reply With Quote
Old 08-07-2016, 02:04 PM   #3
Rewards Points: 18
Yeah man this one is very strange. If there ever were any screws in this one, they probably rusted away. It looks like its actually 2 rings of pvc in the center
Old 08-07-2016, 09:18 PM   #4
Rewards Points: 1,308
I'd leave it where it is since replacing it would mean breaking concrete, may be large area to find where you can cut/rebuild.
The toilet bolt can be any bolt. I'd drill and epoxy stainless bolt and sink it so you don't have to recut later. 3/4 past the toilet and cover will fit and make sure the bolt is plumb to the finish floor. Depends on concrete floor level and if you are going to correct it. Similar or a bit larger than toilet bolts. You want the washer and bolt cover to fit. Vacuum out dust and make sure the hole is in a good condition concrete. Cracked or such condition may not hold the bolt.
You can build up any height difference with the wax ring, not too much since squeeze out can block the drain. Or add a new ring with screws and wax ring sandwich.
carpdad is offline   Reply With Quote
Toilet flange not connected to floor rookie350z Plumbing 10 03-07-2016 02:44 PM
Problem with toilet flange on top of tile floor wspev2244 General DIY Discussions 14 09-12-2015 07:55 AM
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 09:32 PM
Help with old, rusted cast iron toilet flange BigWinston Plumbing 7 08-08-2012 09:02 AM
Toilet Flange Inside or Outside Drain Pipe? sledged Plumbing 23 01-18-2012 12:18 PM
