Cant Remove This Nipple From Main Stack - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree11Likes
Old 02-12-2018, 05:40 PM   #46
retired framer
Rewards Points: 15,276
Re: Cant remove this nipple from main stack
Originally Posted by SeniorSitizen View Post
Being it's a drain I'd exchange the T for a wye clean out but it's not mine and good luck.
He can come out to the sink with a 45, just makes drywalling it a little pain but snacking easier.
Old 02-12-2018, 06:08 PM   #47
retired framer
I found this in a thread on this site.
Old 02-12-2018, 06:15 PM   #48
Rewards Points: 96
Ok i think that makes sense.
In my scenario using an AAV, referencing that drawing would the AAV go on top of the Wye basically?
BrooklynBravest is offline   Reply With Quote
Old 02-12-2018, 06:18 PM   #49
retired framer
In the picture I just posted the gray pipe is the vent and the they show a sink in the other room.
Old 02-12-2018, 06:23 PM   #50
Peace be with you
DR P's Avatar
Rewards Points: 1,860
whew; you all have been busy wood chucks...
sure would have been nice to know you have a 2" PVC
vertical drain to left of metal stack you could have tied into...
your old washer drain most likely did not back up because
it was immediately wet vented through that larger drain pipe...
No; the L/tub should not be trapped if you are using the washer trap.
place a cleanout INTO your L/tub drain where it turns horizontal;
your problems with the new drain branch are it is undersized
& the 90` turns near metal drain stack are not long sweeps -
also I can not tell what amount of slope/fall is on that 1.5"
horizontal drain line; that said - your saving grace is going
to be the capacity of the L/tub should contain any back ups
It would have been simpler to place a 2" drain line behind you wall
tied into the 2" vertical PVC drain, of course vented with an AAV
& incorporating long sweep changes in direction... with good slope/fall
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
Old 02-12-2018, 06:27 PM   #51
retired framer
Peace
You run them both in one trap??? I have never seen that.
Old 02-12-2018, 06:32 PM   #52
Peace be with you
DR P's Avatar
it is an exception in code - think of a double or triple bowl sink
where the 2-3 outlets tie together before being trapped...
Peace
Old 02-12-2018, 06:46 PM   #53
retired framer
Peace
We need you a couple hours ago. I have givin bad advice. That was his plan before I told him to cut it up.
Old 02-12-2018, 07:21 PM   #54
Rewards Points: 96
I can still tie into that 2Ē PVC but truthfully I didnít think it was a vent?
It has a sink coming off of it behind the wall that you canít from what used to be a basement kitchen. From what i see that sink is only wet vented to that pipe so itís not a vent like i need is it?
In pretty sure itís the drain to my bathroom sink.
Old 02-12-2018, 07:24 PM   #55
retired framer
Sorry I was sending you in the wrong direction. I will get out of the way since Dr p is hanging around to help you.
Old 02-12-2018, 07:26 PM   #56
Rewards Points: 96
I knew beforehand it was undersized at 1.5Ē. Problem is that putting it inside the wall with an outlet box was an afterthought. I mentioned making it nicer to my wife and of course thatís what she wants now...
It obviously isnít to code or being inspected regardless but of course i donít want to have problems either.
As far as the elbows go, I need to use a long sweep to create better less turbulent drainage Iím guessing?
Are full 90s no good in this scenario in general?
Before i forget thank you all youíre a huge help. Iím a carpenter not a plumber...
Old 02-12-2018, 07:51 PM   #57
Plumber
TheEplumber's Avatar
Rewards Points: 248
I can't follow 50+ posts but it's this simple
The drain is 2"- exceptable by UPC
Wet vent the sink into vertical 2" washer vent
AAV goes on the vent above the 2 fixtures
Old 02-12-2018, 08:59 PM   #58
Peace be with you
DR P's Avatar
1/4 turn 90s are not allowed for turns horizontally
2 45s together or the equivalent us what is required...
Peace
Old 02-13-2018, 07:19 AM   #59
Rewards Points: 96
Just noticed the drawing i didnít see it prior
So in this scenario i need a p trap below the washer box and one under the sink correct?
Also i need to change out the elbows to long sweep ones?
Old 02-13-2018, 07:20 AM   #60
Rewards Points: 96
Didnít see your reply either.
Ok awesome thank you.
Add vent to main stack LowlyDIYer Plumbing 10 08-16-2017 09:00 AM
Replace my main panel or main breaker? joe_oklahoma Electrical 16 12-15-2015 11:27 PM
FPE Panel change out. Main Breaber to Lug TJ14u Electrical 4 01-22-2013 10:54 PM
Tub and shower directly to main stack? weekendwarrior9 Plumbing 2 10-09-2012 11:52 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 02:47 PM
