Can't Find Vent For Basement Drains - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-10-2015, 12:52 PM   #16
Rewards Points: 1,942
"Ok, I'm glad to admit you know more about it than I do. Can you explain, then, why Definition 177 for "Stack venting" contains the language "venting a fixture or fixtures through the soil or waste stack."?"
There talking about a common vent at the top of the stack. Nothing drains down it from above that final connection.
The Kentucky code is seriously a blast from my past. Much like Ohio code when I was an apprentice.
In the end all they are doing is hurting themselves by not using one of the model codes.
Ghostmaker is online now   Reply With Quote
Old 06-10-2015, 01:05 PM   #17
Special User
Rewards Points: 1,230
Well, I won't claim that the OP's installation is to code, then. But the sink drain is acting as a (possibly illegal) wet vent which is why he's not currently seeing any venting problems.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 06-10-2015, 01:11 PM   #18
Codes are not god like I see a lot of hacked up stuff while inspecting. The only time it hurts is if a plumbing pre sale inspection occurs then it can cost thousands to repair. Some areas in Ohio it is mandatory for the building department to do a pre-sale.
Floor broke up, Rough-in plumb for basement bath collegetry Plumbing 7 01-31-2014 07:24 PM
The Edge Vent/Smart Vent and leafguard User123 Roofing/Siding 5 07-08-2013 10:31 PM
Installing a gable vent..from *inside* the attic steveKane Building & Construction 8 12-09-2012 02:45 PM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 10:40 PM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 12:01 AM
