Can Two Sinks Share The Same Drain/vent Stack? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2015, 05:11 PM   #1
Rewards Points: 6
Can two sinks share the same drain/vent stack?
I'm in the process of starting my basement refinishing project and have run into an issue. I've got a stud wall that is already roughed in for the bath room. I'd like to add a wetbar/sink to the other side of the wall. The problem is there is only one drain pipe. Can I somehow T the drain so I can have sinks on either side of the wall? Do I need to vent the sinks separately? I'll try to attach a picture so you guys can see what I'm working with. And FYI, my plumbing knowledge is very little.
Can two sinks share the same drain/vent stack?-img_20151014_205418215_1444947069969.jpg
Walleye vision is offline   Reply With Quote
Old 10-15-2015, 05:45 PM   #2
Rewards Points: 1,942
We need to know what state you reside in to know what code applies.
Old 10-15-2015, 06:55 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 258
If UPC, You can add a second tee for a bar sink to the vertical drain.
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (10-15-2015)
Old 10-15-2015, 06:58 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 24,848
As I understand it, the Tee for that vent needs to be at least 6" above the fixture.
ddawg16 is online now   Reply With Quote
Old 10-15-2015, 07:01 PM   #5
Rewards Points: 6
I'm in Minnesota.
Old 10-15-2015, 07:03 PM   #6
Rewards Points: 6
By 6 inches above the fixture, are you talking about the horizontal branch already in place?
Old 10-15-2015, 08:19 PM   #7
Eplumber already answered you. Refer to his post.
Old 10-15-2015, 08:40 PM   #8
Rewards Points: 6
What is UPC?
Old 10-15-2015, 08:51 PM   #9
Plumber
Rewards Points: 258
Originally Posted by Walleye vision View Post
What is UPC?
Uniform Plumbing Code
Minnesota has adopted it's own code according to Google
Old 10-15-2015, 11:34 PM   #10
Rewards Points: 6
Ok, I've included another pic and drawn what I think you mean (See the red in the first picture). Is this correct?
I've also added a second picture of something that I was thinking of earlier that makes sense to me, but may make you guys laugh. You never learn unless you ask right!
Thanks for your help
Can two sinks share the same drain/vent stack?-plumb1.jpg
Old 10-15-2015, 11:35 PM   #11
Rewards Points: 6
Here's the second picture.
Can two sinks share the same drain/vent stack?-plumb2.jpg
Old 10-16-2015, 08:26 AM   #12
Plumber
Rewards Points: 258
1st picture is good- 2nd is bad. They must tee off the vertical pipe
Old 10-16-2015, 07:18 PM   #13
The bar sink is usually the higher sink. PS. For those reading this is not legal under IPC due to pipe in the vertical being undersized. And you can not tie a bar sink into an existing wet vent for a bath room.
Can't find vent for basement drains missionman Plumbing 17 06-10-2015 01:11 PM
Drain/vent, 2 sinks jklingel Plumbing 31 03-16-2014 01:33 AM
Vent stack for 3x sinks weekendwarrior9 Plumbing 10 10-10-2012 08:11 PM
OOPS! Stack disconnected when I tested my work... WillK Plumbing 1 02-20-2012 06:04 AM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 12:56 PM
