Can Temperature Affect A Wax Ring? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2016, 09:19 AM   #1
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 12
Can temperature affect a wax ring?
I guess the title asks it all. I had a wax ring fail in an unheated bathroom. The temp in there was 50ish (F) and I was wondering if the temperature could have had anything to do with it failing?
Old 02-11-2016, 09:36 AM   #2
Rewards Points: 18,762
That's not what caused it to fail.
Far more likely something as simple as the nuts where loose and the toilet rocked, bolt broke, broken flange ECT.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
ben's plumbing (02-11-2016), Blondesense (02-11-2016), oh'mike (02-12-2016)
Old 02-11-2016, 09:58 AM   #3
WhatRnsdownhill's Avatar
Rewards Points: 2,220
I have had wax rings melt because the radiant heat was put too close to the flange and the floor temp too high...but low temp wont bother them...X2 on the rocking toilet...or it was never installed correctly...
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
Old 02-11-2016, 11:34 AM   #4
Rewards Points: 352
sometimes a lot of plunging can blow out a waxring
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
Old 02-11-2016, 12:28 PM   #5
Stuck in the 70's
Rewards Points: 12
No plunging, but last month I did have a house full of 3XL house guests using that 45 year old flange.
Thanks all. I'm about to pull it and see what's going on. I just wanted to make sure there was no reason not to use it after I get it fixed.
Old 02-11-2016, 12:57 PM   #6
Rewards Points: 5,450
Temperature didn't do it.
The only way I can see 3XL guests affecting the ring is if the common mistake was made of the flange being too high when the toilet was set. Excess weight was placed on the flange rather than the floor. There is no reason to crush a wax ring more than about a quarter inch.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 02-11-2016, 08:27 PM   #7
Rewards Points: 582
my guess was the 3xL house guest ..not to be rude.. but that can happen bigger and heavier people can rock the pottty breaking the seal
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
Old 02-11-2016, 11:15 PM   #8
Stuck in the 70's
Rewards Points: 12
When I replaced the toilet a few years ago the flange was showing it's age with rust, but I was able to get the bolts secured fine. I think that combined with the extra stress with the house guests, well, as they say... "somethings gotta give." As soon as I can get a few hours off I guess I'll find out how bad it is.
Old 02-12-2016, 08:40 AM   #9
Retired Moderator
Rewards Points: 7,174
There are lots of ways to repair a bad flange---when you pull that---let us know what you find---
Blondesense (02-13-2016)
Old 02-12-2016, 03:24 PM   #10
Oso954's Avatar
Rewards Points: 1,594
Dry fitting the toilet and shimming as necessary will eliminate a lot of ring problems, 3xl or otherwise.
I've seen a lot of people skip this important step thinking the bolts/nuts will keep it from rocking.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Furnace temperature rise (delta) is too high jadziasman HVAC 11 01-04-2015 01:29 PM
Aquastat with low temperature (70F) limit nnniic HVAC 6 12-18-2014 01:43 PM
Temperature trouble with new Mitsubishi mini-splits jeffersly HVAC 12 11-05-2014 06:13 PM
condensation on double pane windows netminder HVAC 18 01-06-2013 07:18 PM
window condensation kmpittman Windows and Doors 4 11-29-2011 09:10 AM
