Canít Get Water To Turn Warm - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 01-13-2018, 05:14 PM   #1
Rewards Points: 8
Canít get water to turn warm
In my bathroom I turn on the hot water and the pressure is great, but no matter how long I let the water run, it wonít get warm. It is only happening in this bathroom. Any suggestions?
briancltpt is offline   Reply With Quote
Old 01-13-2018, 06:08 PM   #2
RRH
Rewards Points: 1,480
Re: Canít get water to turn warm
It could happen with just the tub or shower. But I dont see how with the sink.
You should turn on just the hot on the sink and see if you can hear water running when you put your ear close to the water heater.
RRH is offline   Reply With Quote
Old 01-13-2018, 07:15 PM   #3
Rewards Points: 6,468
Has it always been that way?
Old 01-13-2018, 07:17 PM   #4
Guapo
Rewards Points: 11,950
If it's happening in the shower/tub, there is a setting behind the handle.
Guap0_ is offline   Reply With Quote
Old 01-13-2018, 07:53 PM   #5
Rewards Points: 3,454
Agree with other posters. Check that first. What fixtures? All? May just be a setting issue.
What kind of pipes are running to that bathroom? Maybe old galvanized piping? Just a suggestion.
jmon is offline   Reply With Quote
Old 01-14-2018, 08:19 AM   #6
tom_poconos's Avatar
Rewards Points: 508
Do you have a thermostatic mixer in the bathroom? If so it may be faulty or set incorrectly. I don't have these myself but I just read about them while installing a new water heater.
tom_poconos is offline   Reply With Quote
Old 01-14-2018, 10:36 AM   #7
Rewards Points: 8
No, I just noticed it this week. I’m not sure exactly how long it has been happening.
Old 01-14-2018, 10:38 AM   #8
Rewards Points: 8
Our house is only 3 years old, built by Lennar, so I’m sure the pipes are modern.
Old 01-14-2018, 10:39 AM   #9
Rewards Points: 8
There is no shower in that 1/2 bath, and this isn’t is only happening in this sink.
Old 01-14-2018, 10:41 AM   #10
Rewards Points: 8
I don’t know about a thermostatic mixer. I don’t think so.
Old 01-14-2018, 10:45 AM   #11
I'd bet half of my social security check the above is correct and that the modern must have technology has screwed up once again.
Guap0_ likes this.
Old 01-14-2018, 08:46 PM   #12
Usually Confused
lenaitch's Avatar
Rewards Points: 2,072
Maybe a dumb question but what happens when you turn on just the cold water? If it is a single-control tap, perhaps the mixing valve has failed. Many builders aren't noted for installing high-end fixtures.
_________________________________________
Bydand
lenaitch is offline   Reply With Quote
Old 01-14-2018, 10:37 PM   #13
RRH
There is no shower in that 1/2 bath, and this isnít is only happening in this sink.
So what else is there besides the sink that is not getting hot water.
I still have not understood the answer to that question yet.
Old 01-15-2018, 06:17 AM   #14
Guapo
Request for more details:
Is it a 2nd floor bathroom?
Do the feed pipes travel through an outside wall?
Does it only have a toilet & a sink?
Have you double checked all fixtures, in the house?
List all the fixtures & where they are located.
Old 01-15-2018, 10:29 AM   #15
Rewards Points: 1,942
Do you have single handle moen faucets?
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Can I turn off hot water to Washing Machine? okk Plumbing 12 08-10-2012 07:14 PM
Only warm water in shower - Pfister pvstansel Plumbing 1 09-25-2011 12:42 PM
