Can Someone Suggest A Workaround To Adding A New Bath Vanity/sink? P Trap Hits Shelf! - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree12Likes
Old 01-30-2018, 04:17 PM   #16
retired framer
Rewards Points: 15,304
Re: Can someone suggest a workaround to adding a new Bath Vanity/sink? P trap hits sh
Originally Posted by ron45 View Post
Why not cut the drywall and do what you have to in order to make it work.
Either patch the drywall or just cover it with the cabinet.
That is just what I have been looking at. there is room in the cupboard if the drain was centered.
ron45 likes this.
Old 01-30-2018, 07:21 PM   #17
Rewards Points: 50
Well she's in! Definitely Mickey Mouse Goofy and Donald Duck have to put this vanity in! Feel free to laugh at my amateur hole cutting skills, my crappy Harbor Freight drill and my flip-flops LOL. But I was able to get this thing in with no Plumbing or extra tools whatsoever.
I think half the time was spent with me worrying about whether or not I can make this cabinet work and being afraid of punching a hole through the back. Once I did that and committed to it I just worked it in and made the hole bigger.
Could not have done it without you guys my solution for the plastic slide by the way which hit exactly where the 45 degree drain pipe went into the wall was to Simply hack saw it off about 3 in away from the plastic guide. It may sag when everything is loaded but at least they have use of the whole drawer if needed.
I may end up drilling Maybe a 2 inch circle at the back of the drawer to clear the shutoff valves but the drawer itself has full capacity.
Thanks again for all of your quick reply so I couldn't have done it without all of you.
Cheers, The Count
Can someone suggest a workaround to adding a new Bath Vanity/sink? P trap hits shelf!-20180130_180239_1517360970633.jpg   Can someone suggest a workaround to adding a new Bath Vanity/sink? P trap hits shelf!-20180130_175926_1517361059810.jpg   Can someone suggest a workaround to adding a new Bath Vanity/sink? P trap hits shelf!-20180130_175933_1517361179792.jpg   Can someone suggest a workaround to adding a new Bath Vanity/sink? P trap hits shelf!-20180130_175906_1517361385457.jpg
CountChocula is offline   Reply With Quote
Old 01-30-2018, 07:31 PM   #18
retired framer
Cheers, The Count
Looks good from my house.
Stand 1x4 up from the floor to the bottom of the drain screw threw both lower and higher slider and that will support the drawer.
The cold water tap will be accessable from the left cupboard with the drawer pulled, I wouldn't cut a hole in the back of the drawer.
Old 01-30-2018, 08:32 PM   #19
Rewards Points: 50
That's a good idea Neil with the 1x4.
The back of the drawer hits the front of the shutoff valve that's the only reason why I need to drill it out I just need an inch or two and then they'll have to full drawer floor
Can someone suggest a workaround to adding a new Bath Vanity/sink? P trap hits shelf!-15173659172541064591010_1517365931488.jpg
Nealtw likes this.
Old 01-30-2018, 08:54 PM   #20
ZTMAN's Avatar
Rewards Points: 624
Good enough for government work Count, you did it.
I feel your pain. Just put in one of those "clearance" vanities with my son at his new house. He learned some new words, I got a few more battle scars, but we had a great time doing it.
de-nagorg and Nealtw like this.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 01-31-2018, 12:26 PM   #21
Rewards Points: 6,128
123pugsy and Nealtw like this.
ron45 is offline   Reply With Quote
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 09:31 AM
