Can Someone Help Identify This Type Of Shower 1-handle Faucet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2014, 07:29 AM   #1
Question
Can someone help identify this type of shower 1-handle faucet?
Hi,
I need help identifying this 1-handle shower faucet.
The plastic clip broke and i need to replace it. Don't want to buy a new faucet completely if i can identify exactly the type of cartridge i need.
Thanks!
Can someone help identify this type of shower 1-handle faucet?-20140921_clip.jpg
diymtl is offline   Reply With Quote
Old 09-22-2014, 08:36 AM   #2
adding 1 more picture
not sure if this one is clearer..i initially guessed it was a Moen but i couldn't find the same cartridge when browsing on home depot's sites. may be someone can tell based on the tool required to remove the cartridge?
Can someone help identify this type of shower 1-handle faucet?-20140922_cartridge.jpg
Old 09-22-2014, 09:19 AM   #3
cartridge picture
And here is the cartridge.
Thanks a lot!
Can someone help identify this type of shower 1-handle faucet?-20140922_cartridge_pic.jpg
Old 09-22-2014, 09:34 AM   #4
If I HAD to guess, I'd say it's a Delta. But there are lots of Delta knock-offs out there. It'd be best to take the old cartridge with you to look for an exact match.
And DO NOT throw away the old cartridge until you know the new one works!
Ishmael is offline   Reply With Quote
The Following 2 Users Say Thank You to Ishmael For This Useful Post:
diymtl (09-22-2014), jmon (09-22-2014)
Old 09-22-2014, 09:47 AM   #5
Rewards Points: 3,216
If no luck at the big box stores, take cartdridge with you to your local hardware or plumbing supply store and try to match it up there. Just a suggestion.
Also looks like there is some writing/numbers on the cartdrige. Google the number, it should tell you the brand.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
diymtl (09-22-2014)
Old 09-22-2014, 10:01 AM   #6
thx, i'll get to the big box stores later today.
The # is 04.1.03A and couldn't find anything on google.
I tried a google image search too but to no avail. If anyone knows it or has worked on this, let me know. thx again.
Originally Posted by jmon View Post
+1
The Following User Says Thank You to diymtl For This Useful Post:
jmon (09-22-2014)
Old 09-22-2014, 10:32 AM   #7
Sometimes you get lucky. That number just looks like the date of manufacture. April 1st, 2003. No help.
Stay tuned, one of the plumbers may be able to id it for you.
Old 09-22-2014, 09:18 PM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
try this link http://www.alibaba.com/product-detai...37396.html?s=p
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
diymtl (09-23-2014)
Old 09-23-2014, 07:37 AM   #9
it was a Belanger ceramic cartridge.
Found it at Rona - Belanger Ceramic Cartridge worked.
Thanks all.
jmon (09-23-2014)
Old 09-23-2014, 07:58 AM   #10
Your welcome. Glad everything worked out for you.
Old 02-24-2016, 09:38 PM   #11
I need help. I have this exact cartridge and the same thing happened. How did you remove it from the housing? The curved metal ring is stopping me from accessing anything. Please help. Thank you
sheldonellswort is offline   Reply With Quote
Old 02-24-2016, 09:44 PM   #12
I need help! ! I have this exact same cartridge and the same thing happened. How did you get the cartridge out of the housing ? The curved metal ring is stopping me from accessing anything. Please help. Thank you
Kohler single handle shower faucet loose Liv Plumbing 8 11-13-2015 04:22 PM
Help with Replacing a Shower Faucet adodd87 Plumbing 17 01-21-2012 09:21 PM
Moen Single Valve Shower Handle problem! F8James Plumbing 3 04-16-2011 04:32 AM
Delta Shower Faucet and Valve- plummer botched? twanto Plumbing 3 08-08-2009 08:04 PM
deciphering faucet handle EdPDX Plumbing 1 11-05-2008 07:12 AM
