Can I Use This Saw Blade For Cutting PVC Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-04-2016, 09:47 AM   #1
Rewards Points: 226
Can I use this saw blade for cutting PVC pipe?
Irwin
https://m.lowes.com/pd/IRWIN-Marples...7-051ca5277e65
imola ghost is offline   Reply With Quote
Old 12-04-2016, 10:11 AM   #2
JUSTA MEMBER
Rewards Points: 3,300
Re: Can I use this saw blade for cutting PVC pipe?
In the specs, it says CUTS PLASTIC, so you probably can.
But I use a regular crosscut hand saw.
Unless you need to cut many times, why spend the money on it.
ED
de-nagorg is offline   Reply With Quote
Old 12-04-2016, 10:32 AM   #3
jlhaslip's Avatar
Rewards Points: 708
Looks more like a finishing blade with those 100 teeth, but it will cut plastic as well as anything. You could likely get by with a cheaper blade and less teeth just fine.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Can't drain water from water pipe to outside faucet hansim4 Plumbing 19 02-23-2015 02:07 PM
Deep Pipe Clog - Epic Battle Digi Plumbing 37 02-02-2013 11:48 AM
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 02:46 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
