Can I Use Metric Instead Of Inch? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 2 Post By joed
  • 1 Post By lenaitch
Old 12-01-2017, 07:42 AM   #1
Rewards Points: 16
Can I use metric instead of inch?
Hi
I am about to buy a stock of adapter for water purifier (faucet divertor. please see attached picture), some chinese factories only work with metric system and I wonder if I can use them. my questions are:
1. Some answers I got is that the most common tap would be 55/64(at the connection point to an aerator). Do you agree that this would be the most widely used?
2. Since it is 22mm metric vs. 21.83mm (55/64inch x 25.4mm), and since factories that work with the US make only metric, can I assume that 22mm is also used in the US (no damage and no leaking?).
Thank You
rony1 is offline   Reply With Quote
Old 12-01-2017, 07:51 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 32,036
Re: Can I use metric instead of inch?
The threads must match not just the diameter. I have never seen a metric thread that would work properly on an imperial thread.
lenaitch and ZZZZZ like this.
Old 12-01-2017, 08:22 AM   #3
Rewards Points: 16
yes, I forgot to mention the threads, but I think they are also very close...
Old 12-01-2017, 08:52 AM   #4
JUSTA MEMBER
Rewards Points: 4,002
Very close is not "good enough" when working with plumbing.
Leaks will occur, and then unhappy results.
ED
de-nagorg is online now   Reply With Quote
Old 12-01-2017, 04:08 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 2,112
'Close' only counts in horseshoes, grenades and slow dancing.
de-nagorg likes this.
_________________________________________
Bydand
lenaitch is offline   Reply With Quote
Old 12-01-2017, 04:15 PM   #6
retired framer
Rewards Points: 15,852
There are adapters, It looks like you have to make sure your order lead free???
http://reviews.conservationwarehouse...ucet%20Aerator
Home depot has them
https://www.homedepot.com/p/NEOPERL-...9-05/203673046
Nealtw is offline   Reply With Quote
Old 12-01-2017, 05:20 PM   #7
Rewards Points: 16
OK I got the message. no metric is welcome at the US
And what would be the most common?
at the attachment you can see 55/64F, 3/4F an also they say that there is an option for bathroom M28-1 (what is the parallel in the US?)
so, which one of this three should I go for?
Old 12-01-2017, 05:40 PM   #8
Rewards Points: 16
Old 12-01-2017, 06:08 PM   #9
ZZZZZ's Avatar
Rewards Points: 2,958
I wouldn't go that far. There are plenty of tools, machinery, equipment, parts etc made in the US to metric standards.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Old 12-01-2017, 06:32 PM   #10
Rewards Points: 1,952
Another small detail your stuff must hold a lead free certification. Because it is used for drinking. ASME A112.18.1/CSA B 125.1. ,,NSF 61, Section 9,,
It will need to be tested to meet or exceed the above standards.
Help with plumbing venting solution TRG Plumbing 15 04-08-2017 06:55 PM
8 inch or 10 inch Rafters mrpbody44 Carpentry 2 06-03-2016 09:06 AM
4 inch duct instead of 6 inch buildit45 HVAC 2 10-11-2012 03:16 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
24 inch to 16 inch Centers dsearles Building & Construction 3 11-30-2005 10:20 PM
