Can I Temporarily Replace A Leaking 32 Gallon Pressure Tank With A Smaller Tank? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-27-2017, 09:25 AM   #1
Rewards Points: 6
Can I temporarily replace a leaking 32 gallon pressure tank with a smaller tank?
My Myers MPD31 hydro-pneumatic 32 gallon pressure tank sprung a leak yesterday and needs to be replaced. I already bought a replacement unit but found out at home that its diameter is too wide for the spot where it is supposed to be installed. Unfortunately I won't be able to get a fitting unit today, as the big box stores don't have the diameter/size unit. This situation comes at a bad time, as I am accommodating guests right now who are without running water. That's why I have to come up with a quick compromise solution for the meantime. I was planning to install a water pump system on a campsite on my property to provide it with water from the adjacent creek. For this set up I intend to use a 2 gallon pressure tank, that I could acquire immediately & locally. My question is: Can I use the small unit as an interim solution for the water supply inside my home until I can get the 32 gallon tank on monday? My main concern is for my well-pump. Do you have any recommendations on which small water tank to buy? What do I have to know or keep in mind to make this work? Any help is greatly appreciated, as this is kind of an emergency situation. Thank you very much, naturegirl
naturegirl is offline   Reply With Quote
Old 08-27-2017, 09:57 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,658
Re: Can I temporarily replace a leaking 32 gallon pressure tank with a smaller tank?
A two gallon tank will cause the pump to cycle on and off more than the appropriately sized tank. Is there another area where you can house the larger tank, say in a closet or adjacent space? It would just require extending your existing piping to meet the new tank, but will give you uninterrupted service with good pressure.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 08-27-2017, 10:07 AM   #3
Rewards Points: 6
Hey Chandler, thanks for taking the time to reply. Unfortunately there is no other spot I could place the unit in.
I know the smaller unit is not a perfect solution, but do you think it could work for a day or two until I can get an appropriately sized tank?
Old 08-27-2017, 10:19 AM   #4
Naildriver
chandler48's Avatar
If you can't find an appropriately sized tank, it will have to do, although you must expect the pump to cycle possibly every 15 seconds or so under use. It will wear on your pump, especially with guests taking showers, etc, and the water pressure will take a hit since you are running expressly on the pump without assistance of the storage tank. Can you link us to the tank you are proposing to use?
Edit: from 14 gallons to 32 gallons, the tanks are only 16" wide. Is your present tank smaller in diameter than that?? http://www.homedepot.com/catalog/pdf...3fa7bda186.pdf
Larry......
Old 08-27-2017, 11:15 AM   #5
Rewards Points: 6
Unfortunately those pressure tanks are not available for pick up at the stores that I can reach, they would be a perfect fit though.
Thanks for the suggestion though!
Old 08-27-2017, 11:25 AM   #6
Rewards Points: 6,520
The small tank you are considering will have the draw down gallons stated on the paper work. That's the amount of water used between pump on and pump off cycles. It may be 2 gallon or 1 gallon but you have no choice. Go for it.
well pressure tank not holding at 60 psi sailor dave Plumbing 2 09-10-2013 02:31 PM
septic - could you fill a 1500 gallon tank in 10 months? denemante Plumbing 20 12-10-2012 04:16 PM
well pump, pressure tank issue?? fumbrunner Plumbing 2 11-26-2011 08:51 PM
Hot Water Tank and Pressure Help tbakbradley Plumbing 2 01-17-2011 09:25 AM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
