Can I Replace Packing Nut On Shutoff Without Turning Building Water Off? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2017, 10:17 PM   #1
Rav
Rewards Points: 898
Can I replace packing nut on shutoff without turning building water off?
I've replaced stems and packing nuts in toilet and sink shutoff valves before in my house, turning the main house valve off first.
My Mom lives in a condo and one of her Brasscraft multi-turn shutoffs is leaking from the stem where it exits the packing nut. I've already tried tightening the packing nut. I have a replacement packing nut (with packing washer in it) ready to go.
The problem is the building maintenance guy says he can't turn the water off just to her unit, but would have to turn it off to a whole section of the building.
If I make sure the valve is closed, remove the handle, and carefully remove the packing nut without also turning the stem, can I get away with not turning the water off? Or will I have water spraying out no matter how careful I am? Thanks.
Sent from my iPad using Tapatalk
Rav is offline   Reply With Quote
Old 03-19-2017, 10:23 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 884
Re: Can I replace packing nut on shutoff without turning building water off?
Short answer, yes as long as the valve is closed.
Sent from my RCT6203W46 using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Rav (03-19-2017)
Time to replace hot water tank - options eastcan Plumbing 2 09-26-2013 06:32 AM
Replace toilet water shutoff valve abastin Plumbing 14 02-14-2011 03:41 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
turning off water Jack Hass Plumbing 1 02-03-2007 09:00 PM
