Can I Empty And Reuse Water Expansion Tank? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree6Likes
  • 1 Post By jmon
  • 1 Post By jmon
  • 1 Post By joed
  • 1 Post By AllanJ
  • 2 Post By jaketrades
Old 02-25-2018, 08:49 AM   #1
Rewards Points: 960
Can I empty and reuse water expansion tank?
My momís water expansion tank is full to the brim. Iím currently emptying it out.
Can I just empty and reuse that tank? Iíll bring it back to system pressure.
Or do i need to buy a new one?
Thx
jaketrades is offline   Reply With Quote
Old 02-25-2018, 09:00 AM   #2
Rewards Points: 3,452
Re: Can I empty and reuse water expansion tank?
Those are throw aways jake, imo.
Once filled with water, they have failed. Bladder is shot. It would just eventually fill with water again. Best to buy new one as you suggested.
jaketrades likes this.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
jaketrades (02-25-2018)
Old 02-25-2018, 09:08 AM   #3
It looks like it's for a boiler. Recommended charge is around 12-15 psi.
If it's for a water heater psi should be set at incoming water pressure, around 50-55 psi most homes.
Check and verify xpansion pressure before installation. I know it says precharged, but sometimes they sit for awhile on the shelf and are not accurate. Just a suggestion.
Hope you get it up and running for her soon.
Old 02-25-2018, 11:17 AM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,952
I would start by pumping up and see what happens. It could be the scheader valve is just leaky. If the bladder is gone replace it.
The Following User Says Thank You to joed For This Useful Post:
Old 02-25-2018, 02:09 PM   #5
Rewards Points: 3,424
Expansion tanks with bladders or diaphagms are shot if gobs of water come out the Schrader valve, or after pouring "all" the water out the pipe connection, shaking the tank gives off water sloshing noises..
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
AllanJ is online now   Reply With Quote
The Following User Says Thank You to AllanJ For This Useful Post:
Old 02-25-2018, 04:32 PM   #6
Rewards Points: 960
Advice has been heeded and Iíve replaced her. Thx
Bondo and jmon like this.
The Following User Says Thank You to jaketrades For This Useful Post:
jmon (02-25-2018)
