Calculating Flow From One Pipe Size Into Another (radiant Manifolds) - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-12-2015, 08:27 AM   #1
Rewards Points: 2
Calculating flow from one pipe size into another (radiant manifolds)
I have a general question regarding flow rates for pipes of varying diameters. Suppose I have a pipe that is 3/4" PEX that splits into 5 smaller pipes, say 1/2" PEX. How do you calculate the flow rate for the smaller pipe?
Here's a diagram:
I would prefer to have a formula or to understand how to make this calculation rather than just an answer to my specific example above.
Thank you in advance.
nilyin is offline   Reply With Quote
Gas pipe size for 75,000 btu furnace jbander HVAC 4 01-03-2013 05:25 PM
PVC or CPVC pipe cement steve3847 Plumbing 7 11-17-2012 05:50 PM
what size pipe to use for water main? Cainiac Plumbing 5 04-24-2012 11:57 PM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
