Calcified Water Heater Anode Rod - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-06-2017, 07:01 PM   #1
Rewards Points: 32
Calcified water heater anode rod
Our gas water heater is about 4 years old. I learned about replacing the anode rod to extend the life of the tank, so I decided to take a look at the condition of it. I had to use an air impact wrench to break it loose, but here's what it looked like. Our city is notorious for hard water, so it's no surprise.
I replaced it with one of those flexible segmented rods since the space was too tight. I had to cut the old one out in pieces.
brian0918 is offline   Reply With Quote
The Following User Says Thank You to brian0918 For This Useful Post:
SeniorSitizen (01-06-2017)
Old 01-06-2017, 07:25 PM   #2
Rewards Points: 19,008
Re: Calcified water heater anode rod
OK, so have a water test done the see if you need a water softener.
Hard water is going to destroy anything down line from the incoming line.
Old 01-06-2017, 07:43 PM   #3
Rewards Points: 32
Thanks, I wasn't really asking for advice, just showing how bad it was. I'll look into getting the water tested though.
Old 01-06-2017, 07:49 PM   #4
Rewards Points: 1,054
Did you flush out the corrosive sediment from the bottom of the tank?
clarenceboddick is offline   Reply With Quote
Old 01-06-2017, 07:50 PM   #5
Rewards Points: 32
I'm going to tonight. I was waiting a while for it to settle.
Old 01-06-2017, 07:53 PM   #6
We own three homes and none of them have an anode rod that looks that bad.
Old 01-06-2017, 07:58 PM   #7
Rewards Points: 32
I found a report from the city that states that their softening process brings the water down to a hardness of 160-180 ppm CaCO3. Not sure if that's high. Some scales show that it's normal, others say that it's high.
Old 01-06-2017, 07:58 PM   #8
Why wait?
Water heaters need to be flushed every 6 months to flush out the solids in the bottom of the tank, almost no one ever does.
Never done it, cheap plastic valve then go buy a garden hose cap because it's not going to shut off all the way.
Old 01-06-2017, 08:01 PM   #9
Get a real test done, it's not in there interest to so the real results.
Old 01-06-2017, 08:07 PM   #10
If your tank has a plastic drain valve, I'd replace it with a brass one or a custom ball valve drain spigot. The plastic port type drain valve clogs very easy.
Old 01-06-2017, 08:20 PM   #11
Rewards Points: 32
Yep, it's plastic. It's worked ok so far but I'm expecting it to snap off one of these times. Do you just drain the tank and unscrew it and screw on a brass one?
Old 01-06-2017, 08:26 PM   #12
Yes, but they are pretty tight. I think they use a thread glue like Loctite on them.
The Following User Says Thank You to clarenceboddick For This Useful Post:
brian0918 (01-07-2017)
Old 01-07-2017, 09:43 AM   #13
If you replace the valve do yourself a favor and use a 3" brass nipple, a ball valve, then a garden hose adapter.
Pay attention when installing the valve to make sure the handle has room to swing open.
Shopping for New Electric Water Heater Lots of Questions LeakyHawaiiRoof Plumbing 3 11-02-2014 01:18 AM
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water Heater Anode Rod NitroNate Plumbing 3 07-20-2014 04:03 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
