C-PVC Ball Valves - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2016, 06:25 PM   #1
Rewards Points: 1,280
C-PVC ball valves
I have in my bathroom (under the vanity) C-PVC lines, with C-PVC ball valves
I want to replace the valves by brass ball valves. What is best:
1) Use Sharkbite fittings
2) Use some kind of C-PVC/copper or brass fitting to be glued?
french_guy is offline   Reply With Quote
Old 02-04-2016, 06:28 PM   #2
Rewards Points: 582
just use a sharkbite...simple and fast..
The Following User Says Thank You to ben's plumbing For This Useful Post:
SHR Plumber (02-04-2016)
Old 02-05-2016, 05:02 AM   #3
OK, thanks
Now, if I were to decommission that vanity and cap the 2 pipes, should I use a Sharkbite cap or a C-PVC glued cap, knowing they will be inside the wall?
Old 02-05-2016, 06:54 AM   #4
Rewards Points: 582
OK, thanks
if its inside the wall ..use cpvc cap and glue...sharkbite fittings should remain accessable....
How long are 1/4-turn ball valves supposed to last? Druidia Plumbing 9 05-18-2015 07:31 AM
PROMAX Ball valves OK? agoodboy Plumbing 2 04-09-2013 02:56 PM
which Ball Valves for potable water? agoodboy Plumbing 5 04-05-2013 08:40 PM
check out the new ball valves! wombosi Plumbing 7 02-03-2009 09:00 PM
Sweating Ball Valves 47_47 Plumbing 7 10-21-2007 08:13 PM
