Bypass Water Softener For External Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-17-2016, 11:15 AM   #1
Rewards Points: 14
Bypass Water Softener for External Faucet
Can't say I've really ever done any plumbing work but this looks simple enough so figured I'd tackle it myself.
When my softener was installed, they didn't bypass it for the exterior faucet. I'd like to do that so I don't have to keep manually bypassing the softener when watering the lawn.
In the picture on the right you can see the pex line coming into and out of the softener. In the upper left, you see the pex line with the red valve on it. That is the external faucet line.
So I just have to tap into the pre softener pex line and connect it to the external faucet line. I just don't really know the procedure. Or how to cap/block the copper block once I remove the line.
Any input would be much appreciated.
Bypass Water Softener for External Faucet-20160817_094006_hdr.jpg   Bypass Water Softener for External Faucet-20160817_093944_hdr.jpg
auzzzie is offline   Reply With Quote
Old 08-17-2016, 08:55 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 1,770
Re: Bypass Water Softener for External Faucet
The concept seems fairly straightforward but I have not worked in pex so you should wait for others to drop by. I know it requires a special crimping tool. You need to add a 'T' to the pre-softener (input) line for the outside faucet. I would think there is some type of cap available for the copper manifold. Otherwise, you could simply leave the red shut-off in place ready for a future use.
lenaitch is offline   Reply With Quote
Old 08-17-2016, 10:24 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 180
This is correct. Except you could bypass the tool and ring purchase and use "Sharkbite" fittings- tees and caps are available in their product line. Leave the pipe after the valve a little long for the cap
The Following User Says Thank You to TheEplumber For This Useful Post:
lenaitch (08-18-2016)
Salt based water softeners destroy septic? JPCheslock Plumbing 14 09-15-2015 08:13 AM
Water softener installation word2yamutha Plumbing 7 09-28-2013 12:27 PM
WHES40 Water Softener Water Meter Mudlvr Plumbing 4 08-18-2012 04:29 PM
Installing a Water Softener amorak Plumbing 3 05-04-2012 10:56 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
