Bury PEX Or PVC For House Main - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree5Likes
  • 1 Post By joed
  • 3 Post By Bondo
  • 1 Post By jeckel7234
Old 03-27-2017, 05:46 AM   #1
Rewards Points: 94
Bury PEX or PVC for House Main
Which product would be best to bury for a water main? I live in NE North Carolina.
PEX
PVC
CPVC
jeckel7234 is offline   Reply With Quote
Old 03-27-2017, 06:08 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,338
Re: Bury PEX or PVC for House Main
All of them can be buried. PVC is used the most prolifically for this and is well proven.
Old 03-27-2017, 06:59 AM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,962
Polyethylene pipe is used a lot for underground water.
Bondo likes this.
Old 03-27-2017, 07:13 AM   #4
Rewards Points: 94
So, currently I have PVC ran as my main and then transitions to qwest once it comes into the crawl space. Im planning on replacing all the qwest with pex this weekend.
My debate is assuming the PVC is 25 years old, replacing the PVC (there currently are no issues) with PEX, or replacing the PVC with new PVC or leaving the PVC and transition from PEX
Old 03-27-2017, 07:14 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,250
Ayuh,.... 'round here, all new mains are HDP poly pipe,....
No joints, No leaks, cheap, 'n easy to run,....
Looks, 'n works like pex, just bigger/ heavier,...
joed, MTN REMODEL LLC and lenaitch like this.
Bondo is online now   Reply With Quote
Old 03-27-2017, 07:37 AM   #6
+1
HDPE is run here as well on well hook ups to the home.
To the OP, PVC doesn't really break down as long as it isn't exposed to UV light.
Old 03-27-2017, 07:44 AM   #7
Civil Engineer
Rewards Points: 5,246
If this is a water main from city water, you need to find out what products are acceptable to the water supply district. If this is a private well, there may be regulations enforced by the Board of Health (that is how it works in my town). If there are no regulations, I second high density polyethylene (HDPE), it comes in rolls, so you can bury a single length of pipe with joints only at the two ends.
Old 03-27-2017, 08:19 AM   #8
Rewards Points: 6,464
Another factor in the decision could be the "Gopher Factor". Information is rather sketchy and I seriously doubt the manufacturer or supplier of Poly pipe would reveal any information about Gopher chewing. I had first hand experience with it 50 years ago repairing Gopher chewed leaks but possibly ( hopefully ) the chemical formulation has changed since then to solve that problem.
Gophers don't seem to bother PVC.
One source copied:
I'm so frustrated: I used drip irrigation in my orchard for several years and liked the way it saved water but gophers repeatedly destroyed the tubing. The worst part is that I wouldn't even notice most of the time because they chew their little holes in the underside of it. I tried both the 1/4 inch tubing and the 3/4 inch, they gnaw through them both. Sometimes my trees would suffer before I realized they were not getting water because some varmint had created his own drinking fountain. I spent every weekend repairing them.
My question is, does anyone know of any type of drip irrigation that would be gopher proof? There must be something I could find that they can't chew through. Or do you have any ideas on how to make it gopher-proof? Getting rid of all the gophers is not an option. They are as numerous as the stars in the sky.
Old 03-27-2017, 01:48 PM   #9
Bondo's Avatar
One source copied:
Ayuh,.... Generally speakin', a water main lateral is considerably deeper than a lawn sprinkler system,...
Old 03-27-2017, 02:52 PM   #10
Rewards Points: 1,942
Ghostmaker is online now   Reply With Quote
Old 03-28-2017, 10:54 AM   #11
Rewards Points: 94
thanks everyone, as of now im planning on leaving the burried pvc in place, and replacing everything else with pex
rjniles likes this.
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Main Electric Panel Help Redrum Ninja Electrical 13 10-22-2011 07:28 PM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 04:52 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
