Broken Toilet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By rjniles
  • 1 Post By DTZee
Old 10-20-2018, 04:27 PM   #1
Rewards Points: 37
Broken toilet flange
Is there any tips you can give me on replacing this. I was installing new toilets in my girlfriends house and the flange on the one was broken. I've replaced many toilets in my life but never a flange.
Sent from my SM-G960U1 using Tapatalk
DTZee is offline   Reply With Quote
Old 10-20-2018, 04:45 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 204
Re: Broken toilet flange
Google "toilet repair flange".
Sent from my RCT6213W22 using Tapatalk
COLDIRON likes this.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 10-20-2018, 04:54 PM   #3
Rewards Points: 3,260
Please inform us if you find a good video.
Old 10-20-2018, 05:20 PM   #4
Rewards Points: 37
Thank you. Thank you all. Great help. If there weren't 5 different types of flanges I would have skipped that. After googling for 30 minutes with no good answer let me ask this. Hopefully Google it isn't the answer. It's a pvc flange with a metal ring. Clearly the metal ring it corroded. Cutting out the old pvc seems like a pain. Could this be fixed with one of those stainless steel repair rings or should I get cutting and hope for the best.
Old 10-20-2018, 07:43 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,938
Ayuh,..... Once ya get the rotten ring off, 'n clean up the mess, You can decide whether the plastic is unbroken, 'n serviceable,.....
If the plastic is Ok, go to the replacement type bolt ring, 'n finish the job,.....
The story goes, ya take things apart, til ya get to serviceable parts, then replace the stuff ya took out,.....
If ya gotta replace the Pvc, look into internal cutters,....
Is there access from below,..??
Old 10-20-2018, 09:22 PM   #6
Rewards Points: 37
I was able to get the corroded ring off after a bit of work. All the screws were corroded and stripped. The PVC is in great condition. I finally found a video of just replacing the ring. I think this is the route I am going to do for now. I can get to it from below if I remove the insulation and drop ceiling in the basement. I didn't look into it that far. I could have likely got it done tonight but the hardware store closed at 5, ugh.. small towns.
Bondo likes this.
Old 10-21-2018, 11:01 AM   #7
Rewards Points: 982
Small towns are such a pain. Did you phone them and ask if they would put the parts at the back door?
fireguy is online now   Reply With Quote
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 10:32 PM
Toilet flange too high ScottyB Plumbing 7 11-20-2012 08:25 PM
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
tile and toilet flange benshouse Plumbing 3 12-29-2010 07:02 PM
Broken floor flange for toilet billy Plumbing 10 03-13-2008 08:58 PM
