DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Plumbing (https://www.diychatroom.com/f7/)
-   -   Broken toilet flange (https://www.diychatroom.com/f7/broken-toilet-flange-644297/)
DTZee 10-20-2018 03:27 PM
Is there any tips you can give me on replacing this. I was installing new toilets in my girlfriends house and the flange on the one was broken. I've replaced many toilets in my life but never a flange. https://uploads.tapatalk-cdn.com/201...d42d630e70.jpghttps://uploads.tapatalk-cdn.com/201...10ab237582.jpg
Sent from my SM-G960U1 using Tapatalk
rjniles 10-20-2018 03:45 PM
Re: Broken toilet flange
Google "toilet repair flange".
Sent from my RCT6213W22 using Tapatalk
SeniorSitizen 10-20-2018 03:54 PM
Please inform us if you find a good video.
DTZee 10-20-2018 04:20 PM
Thank you. Thank you all. Great help. If there weren't 5 different types of flanges I would have skipped that. After googling for 30 minutes with no good answer let me ask this. Hopefully Google it isn't the answer. It's a pvc flange with a metal ring. Clearly the metal ring it corroded. Cutting out the old pvc seems like a pain. Could this be fixed with one of those stainless steel repair rings or should I get cutting and hope for the best.
Bondo 10-20-2018 06:43 PM
Ayuh,..... Once ya get the rotten ring off, 'n clean up the mess, You can decide whether the plastic is unbroken, 'n serviceable,.....
If the plastic is Ok, go to the replacement type bolt ring, 'n finish the job,.....
The story goes, ya take things apart, til ya get to serviceable parts, then replace the stuff ya took out,.....
If ya gotta replace the Pvc, look into internal cutters,....
Is there access from below,..??
DTZee 10-20-2018 08:22 PM
I was able to get the corroded ring off after a bit of work. All the screws were corroded and stripped. The PVC is in great condition. I finally found a video of just replacing the ring. I think this is the route I am going to do for now. I can get to it from below if I remove the insulation and drop ceiling in the basement. I didn't look into it that far. I could have likely got it done tonight but the hardware store closed at 5, ugh.. small towns.
fireguy 10-21-2018 10:01 AM
Small towns are such a pain. Did you phone them and ask if they would put the parts at the back door?
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
